Sekred
- Dec 18, 2021
- 480
- 621
Interesting.
An increase in wear metals in the oil, such as iron and copper, which are strong oxidizers, raises the probability of LSPI.My take per the below is the improvement in aged oil LSPI protection is the only large difference, which then begs the question, when is oil considered "aged"?
Every 3,000km, Engine oil and gear oilAn increase in wear metals in the oil, such as iron and copper, which are strong oxidizers, raises the probability of LSPI.
A decrease in zinc and molybdenum (ZnDTP and MoDTC), which are anti-oxidants, has a similar effect.
I’m not sure about the exact threshold, but I believe that as long as you change your oil at reasonable intervals, everything should be fine![]()
The G16E-GTS engine uses low-tension rings, which means ring gaps should be evaluated accordingly. While it's true that low-tension rings scrape off oil less effectively, using 0W-20 oil helps compensate for this. Also, the cylinder wall roughness (RA) is specifically designed for 0W-20 oil, not 5W-30.
Thank you everyone for the help in letting me understand the problem more and more.
I also found some good YouTube videos that help explain it a bit.
I have found one video with a video section that I found especially good in helping to understand why to use 0W20 and not 5W30 (without even naming viscositys):
(section ends at 4:32)
On top of that, @tonic wrote here:
To reduce the LSPI risk even more, the piston rings need to be able to scrape off the oil, back down into the oil pan.
With thicker oil (like 5W30), there could be some spots left that ultimately lead to a LSPI scenario due to Oil + Fuel + Air mixture and then kaboom.
Yea... I'll think I go with the Ravenol DFE 0W20...![]()
... at 10000 km i will be going back to OEM oil as certain Toyota changes, atleast in the BALTIC Toyota region have pushed us to do so to the detriment of our clients wallets...
Well, in my mind, things can change further, for example ,in Baltics, as far as I know, you have to do the maintenance at a authorised repairer or dealer for it to count at all for example within the standard warranty period, I better not risk it on account of oil, we shall see, 1700 km left for me till first real maintenance of 10000 km.The limitations of the Relax warranty (5 to 10 years old, <100k miles) with reference to using aftermarket parts & fluids for servicing apply to the UK too.
But what are the changes and new limitations that led you to revert back to OEM engine oil for a car that's still under the initial manufacturer's warranty?
(I understand that Toyota GB doesn't mind aftermarket engine oils, etc as long as these meet the spec set by Toyota.)
I use this oil for my car: https://www.mobil.com/en/lubricants...s/products/mobil-1-extended-performance-5w-30
Engine is in stock form, only driven like 1,500KM or less in 6 months then change to new oil.
5W30 because I live in tropical and hot climate country.
Am I doing it right?![]()
As long as it is API SP, you will be fine. There are some overly sensitive warranty nannies that will disagree however.I use this oil for my car: https://www.mobil.com/en/lubricants...s/products/mobil-1-extended-performance-5w-30
Mods which aren't allowed strictly speaking.The maker advises 0W20 - GF6A whatever climate area. In warmer countries, it's wiser to change oil more often / earlier than specified by maintenance book, unless you have an oil cooler and/or a larger oil sump.
what's the replacement?/One - what am I doing here don't even own a GRY anymore - hp
don't use my wording in warranty resoution but I think if you are careful with your car, warm the engine up nicely etc its not that disaster idea to use heavier oil. that being said, it can result in more issues if you floor the car wrecklessly in cold and don't mind chaning the oils. its a system, not a culprit of one individual issue.Mods which aren't allowed strictly speaking.
Also not sure the LSPI failure mode on the GRY is the cold engine scenario, all failures seem related to hard driving with high engine/oil temperatures. So the logic "it's hot I can use higher viscosity" isn't really based of anything as long as the LSPI happening isn't fully understood. If it involves weak piston rings higher viscosity probably doesn’t help...
Best bet is changing oils often. Didn’t the manual state one should change engine oil after a track day??
Still curious/interested and will deffo mis it during the best winter days....- it sticks…..
LSPI_free_+_no_engine_warmup Blue Pill driver+fam car...what's the replacement?
Defective batteries are a thing, 8 yr/200'000km warranty helps....Runaway, not really...Thermal Runaway?![]()
