I think you’ve got that just right on all counts - well playedJust realised I never posted a pic of my Reyland AP setup.
Thanks, I’m pretty happy with it as it sits now. I’ll probably look to get a slightly quieter exhaust in the new year (currently have a Remark axle back) though as it’s currently a bit too spicey for some tracks.I think you’ve got that just right on all counts - well played
If both did it I’d have thought so, but it’s only whirring on the OSF and the tapping is from something on the NS…Aren't odd noises like that the norm when using discs with holes or cutouts?
Excellent information, thanksMorning
You will get some noise from grooved discs
The clip you see on the pad is a wear sensor , when the pads wear down to that point it makes an annoying screech sound to tell you the pads are low , quite primitive but the way a lot of pads are.
You will get noises ect as everything is bedding in , the fronts should be all done by about 400 miles , the rears could take twice as long as they don't get used as much as the fronts , so all seems normal during this process
Hope this helps
Cheers Ian
Looks perfect!Just realised I never posted a pic of my Reyland AP setup.
ThanksLooks perfect!
How much lower does the car sit than stock, and what is the rim size/spacer size? I'm looking at coilovers, ARP extended studs for spacers, as well as 225/40R18 tires for my 8 inch wide rims (once the OEM tires get worn out) and your setup seems very close to what I want to fill out the wheel arch.
And to stay on topic: I might also have to look at getting some new brakes now that i've seen yours..
