Michael Knight
In Finland - normal weather. Like it cool .The bike
Looks cold where are you!
I think for bikes its good. For big cargo carrier maybe not as inclining roof makes it a big wing in higher speeds.Yes! This is the content I've been waiting for
How about two bikes...?![]()
Visited your beautiful country once in Summer !In Finland - normal weather. Like it cool .![]()
Had trouble with my exhaust when opening!I think with bike it is already plenty as it eases making biking trips alot - no need to pack bike inside car.
Only downside is with this spesific bike carrier that it is bit tricky to put bike on and off especially if its windy. But it's doable once you pay attention.
pacificrepworks.com
Wouldnโt the metal clamp be in straight metal to metal contact to cars roof or is it coated with rubber?Clamp photos
yes.This part.
YesOk, but wouldnโt it still be in metal to metal contact even if they were 20mm longer?
The fit of the foot does not need or want to be on the Carbon roof . The clamping mechanism pulls very tight on the sloping area . I agree a longer clamp foot Might be better and did ask of anyone knew anyone at Thule to make one !!Hello, everyone,
Thank you Lanman for putting your kit together.
the rear clamp doesn't quite match the rear roof rail of the yaris gr.
I did a bit of research on the Thule website and downloaded and compared a number of clamp documents.
you use the clamp 145079 of the madzda cx-5. (color orange)
I've now shortlisted them
mini clubman (green) / honda civic (blue) / toyota chr (pink)
and as you can see, the clamp of the chr is much longer and could fit.
what do you think?
since my yaris is still to come it would be great if one of you could measure and sketch the sidecut, then you can compare and see it right here.
Best regards
mixmaxe
The Thule clamp feet are coated and have not marked the lip rear when superhavent noticed, though haven't used those roof bars for a while. you could add something protective in between the metal surfaces, just need to be clean to avoid any dirt in between the surfaces.
C-HR looks better at least for rear bar. what is that stud in the shadow pic pointing 11:30? assuming leg does not have that?Hello, everyone,
what do you think?
Best regards
mixmaxe
What exactly do you mean with the stud in the shadow pic ?C-HR looks better at least for rear bar. what is that stud in the shadow pic pointing 11:30? assuming leg does not have that?
I might have a test with C-HR as was also looking a kit with a longer legs..
