GR Yaris The EcuTek thread
Would it be fair to invite tuners to comment on this thread, after all they can promote their business.
I would think it would become a Willy waving competition. In my opinion it should be for end users to talk about what’s good, what’s not and their experiences. That advertises the tuners. Just one opinion though
Finally got round to flashing the ECU with the basefiles and initial impressions are that it pulls a lot harder and with more urgency (map 3 99 octane) than stock and even the DTUK V1 I was running before using my bum dyno, and a lot harder than any tiny 1.6 3 pot has a right to! Will do some data logging now to get a revised file and get myself on a proper dyno in due course then share the results.
Notes:
Along with the remap I currently have an Eventuri and HKS Legamax exhaust. Ambient temperature was 15c with 76% humidity with a few spots of light rain.
App / dongle firmware needs to be updated first and also the EcuTek servers are a bit sketchy and initially kept failing to handshake authenticate to program map, but a quick call to Iain Litchfield (option 2) and he got them to reboot server, and all good on second attempt five mins later.
Oh and TPMS had a bit of a hissy fit after flashing ECU and clearing DTCs, but a quick 5 min drive calibrated it and cleared the error.
Also looking forward to V2 driveability reports especially those with remote tuning. Thinking about the OE map tendency to feel inconsistent in boost, and with additional hardware to be very active on the recirculation valve on part throttle.
Appreciate this will take time.
I think in the short term they are to busy reacting to demand and dealing with the collective learnings of the data being received back in from customer log files. It might be best to call them and ask any specific questions directly until the bowl wave of interest dies down.
Yeah user experience foremost was my intention.
A) Was initially uninterested in the launch features, but the realised it is very easily allows one to set the launch rpm with the cruise set buttons, so could actually help to make clean and low stress starts.
B) Flat foot shift is the next best thing to a sequential with no loss of boost between changes. Works well?
C) If I read the release notes correctly, car will default to map 1 when switching on car. Can anyone confirm? This would actually be an advantage to me if one can put a base map there with stock power.
Any experiences?
Also, I suppose anyone following this thread goes in eyes open, but for the sake of clarity on some things mentioned, it's good to read the terms of LM as a general reminder as similar (or worse) applies for all mapping:
For customers asking for the removal of Catalytic Convertors or Gasoline Particulate Filters (GPF/OPF) this is strictly for Motorsport use only as the car will not be emissions compliant for UK road use. If a vehicle is being used for Motorsport purposes then we can modify the emissions system but the vehicle will need to be removed from the premises on a trailer and the customer will need to sign our waver to confirm it will not be used on the road.
Upgrading vehicle performance can affect the vehicles reliability and will require more frequent maintenance. Litchfield take no responsibility for component failure after upgrades have been installed.
Litchfield offers no warranty on vehicles upgraded unless specifically put in writing to the customer. If a warranty is provided this agreement does not cover circuit use, sprints or timed events as per most manufacturer warranties."
Source complete terms
Any experiences?
It does, and I already find this of mild annoyance because of the 'Turn off auto stop-start / turn off lane guidance / set track mode / turn of TCS' button press debarcle each time I start the car.
Having to hold down cruise until you get it to 1000rpm and then 3x set button to get to setting 4 is just another inconvenience. I'm asking today if I can have the defaul set to 99RON mode.
*Edit: I've just called Litchfield and asked whether they can speak to Ecutek about setting a default map in the ECU
** UPDATE: Ian's just called me to offer to switch map 1 & 3 around so the car defaults to 99 Mode until a default setting is put in place; that's customer service
It does, and I already find this of mild annoyance because of the 'Turn off auto stop/start / turn off lane guidance / set track mode / turn of TCS' but press debarcle each time I start the car. Having to hold down cruise until you get it to 1000rpm and then 3x set button to get to setting 4 is just another inconvenience. I'm asking today if I can have the defaul set to 99RON mode.
Could move the map4 settings to map1 position??
I'm thinking it good to warm the car on a less aggresive map, and when all temps are up, move to the 99+ or similar map.
I think 1000rpm setting shows you it's moved into selection mode, press set once it's moved it to 2,000 rpm (map 1), 3000rpm (map 2), 4000rpm (map 3).
I'd a tedious p***k so I'm miserably anal about warmup & cool down routines on charged vehicles so I'm not hugely concerned about the risk of being on the 99RON map from start up.
Been out and done some data logging today on base file to send over for a revised map. Done a mixture of general driving then a couple of under load WOT pulls in 3rd and 4th as requested. Did have one instance of the car hesitating and constantly venting / recircing boost activity with a “stustustustu” noise from the Eventuri in 6th under load but only happened once. Didn’t happen again in any other gears and all logged so sent it all over, but was very disconcerting. Checked intake and surrounding area and piping / tubing and nothing appears to have popped off or burst. Weird!
Any thoughts or similar experiences great hive mind collective?
I think that’s just the engine loading up at low rpm but with a high load applied, resulting in turbo flutter. Mine will do similar if I do that but you really have to engineer it.
Ordinarily I’d never bury the throttle at very low revs as have read the other thread about the associated dangers and my driving style is to roll on the throttle. Anyway, it’s probably all captured on the logged drive so hopefully Litchfield can have a good nosey then send through a revised and custom file that’s more suited…
Agree. I only ever encountered it on the motorway in 6th when I was lazy and did not change down
Any error codes on the boost valve? I wonder if turbo was trying to operate outside of expected window or the boost valve plunger stuck temporarily and the pressure came back through the impellor. Intrigued to see if they find anything
I didn’t look at the actual log as I wouldn’t understand any of it anyway but have sent it all off to Litchfield to take a look at and comment and revise my maps. The DTC log shows a “air intake control valve circuit” error but presumably that’s because of the Eventuri and the solenoid no longer connected? I did check to see if the T piece plug is still attached though.
