I got mine by pumping the seat up as high as poss and reaching in from the front was pretty easy. I didn’t have to remove any trim etc as the instructions sayMy lowering plate came today. How on earth have you guys installed the rear bolts?!
Any tips?
Took 5 mins to remove seat and install lowering plate. Then spent nearly a hour trying to fit the back bolts. I've just given up and come back in house.. Maybe try again tomorrow haha
What one? I have ordered a dna kit that lowers but keeps the sliders will report back once I receive it and fit from @MicloiHi guys, FWIW I am testing an alternative pretty soon, should have a video of it within the few weeks. Similar design, loses the sliders and drops the seat a good way. Will update when I have more info![]()
SW MotorsportWhat one? I have ordered a dna kit that lowers but keeps the sliders will report back once I receive it and fit from @Micloi![]()
You don’t have to have the seat pumped up if you unclip the airbag plugs from under the seat.Is the 35mm height reduced measured from the seat pumped up or down? It says the to leave the seat pumped up after installation but is that not going to be higher than when the seat is pumped down on the sliders?
Is position 1 right back?You don’t have to have the seat pumped up if you unclip the airbag plugs from under the seat.
The only reason to pump it up is in setting 1 (the only setting without spacers installed) to stop
The plugs being crushed
Even pumped up to clear the plugs in the normal fixings it’s massively lower than standard. Easily 35mm lower. Position 1 doesn’t use the 5mm spacers so take that into account.
I unclipped my plugs and moved them Out of the way and have it as low as possible. It’s so low that the plastic side trim touches the carpet now
Yes it’s the furthest back but it’s not much more than standard looking at how close it is to the rear bench there can’t be much in itIs position 1 right back?
You are removing the runners which are a good 35mm thick. You don’t need to pump the seat up as I previously postedCan somebody please measure the distance between the seat fixings as they sit on the plate? As in the distance between the holes used.
I am trying to understand how the height is reduced? A pumped up seat is about 40mm from the roof (headrest) and a pumped down seat is about 85mm from the roof so even with reducing the height by 35mm the seat would still be 10mm higher?
In the seats lowest setting the plastic side trim next to the pump handle touches the carpet and then more if you keep lowering so measure the distance between the bottom of the plastic and the carpet and that’s what you are losing in reality
Yes the instructions recommend pumping the seat a few times to prevent crushing the plugs but if you remove them from the underside of the seat you don’t have to do thisIts in the instructions that you leave the seat pumped up, that's why I was wondering where the claimed height drop comes from.
I will have a look at that plastic and the gap, thanks. Does any other parts foul? The airbag plugs were mentioned? Anything else?
