has more information and better interfaceI wanted to ask without stepping on anyone's toes. But why do you install these displays, they look even worse than the original? What is the use of them? I still don't get it?
Ah, ok. Thank youhas more information and better interface
Thanks for the info. It's just a matter of taste, to me it just looks "cheaper". But the display in the GRY is rubbish anywayWireless carplay, high resolution, bigger display.
Also I don’t see how this looks worse? Especially the one in my thread looks much cleaner than original imo. The original one looks straight out of a 2005 VW.
Did you have any empty connections on the rear?Today I installed the screen and it works (mazda 2 hybrid )
I have an energy indicator, tire pressure and fuel gauge. Upgrade the software, everything is fine. Connecting to the carlinkit usb kit also worked. The watch also works well.
The only issue I have is a Pioneer GM D1004 amp I bought and don't know where to put it. behind the radio? will it all get hot enough together? or in the cupboard or under the seat, which will greatly increase the installation costView attachment 28413
1 (5 pin)Did you have any empty connections on the rear?
Plug and playHello,
can anyone help me on this...
I will like to change the screen on my GR from Yaris Cross but if I will buy the screen from eBay they have any security code, or is plug-in-play?
Thanks!
Hello Lee, thank you for your reply. I didn’t have this unit.There is a unit that sits on top or under the main head unit but I have not re fitted it with this connected!
Hi @takis1964 , thank you for your reply. I still have some doubts/questions for you:Good evening, the screen upgrade worked the next day. Do you connect the screen to wifi? I also connected it to the my t application and scanned a qr code. Then it login with the my t account and the screen is connected to the server.Then it does update
Many thanks, bro!Plug and play
