GR86 Real World MPG
What is your real world average MPG?
  • Total voters
    196
It will be instant, the car adjusts its short term fuel trims continuously
Thanks
and the knock sensor will pick up any detonation which will tell the ECU to alter timing and ignition.
But the knock sensor won't be activated if it's not knocking, and it won't be knocking if you're just running up to 4k rpm, only if you're pushing it?
Thanks
The knock sensors detect and relay info back to the ECU, it's then upto the ECU what it wants to do about it. Knock sensors measure crankcase harmonics to pick up detonation (literally a vibration sensor) they are an analogue device so it's not a case of on or off they are always measuring those vibration levels. You also have 2, one on each cylinder bank. It will measure the whole rev range, you can get bad knock down at low rpm under heavy loads, sometimes my GT86 used to pink on a hard pull when it wasn't quite upto temp.
I’ve found my cars run rough on the E10 and smell of fuel. Even the ones that are meant to be able to use it. I use E5 even in the ones that don’t technically need it.
My other car runs smoother on E10 than E5, but fewer MPG. Problem with the GR86 is the manual stating use super unleaded and that's only E5 as far as I know.
I'm due to brim the car today if I can shake off the man flu I have ;-) so I think I'll use the e10 this time as i'm running in at relatively low revs and see how I go
For a totally full tank it's about £7 more for the premium
So I filled up today and used e10.. Definitely feels flatter than it did.. So I’ll give her the good stuff next time 😬
Bonnet dent now invisible and (after a few conversations) made the dealer realise that the locking wheel nut socket I had was not the one for the locking wheel nuts…
New set fitted and the corresponding socket now secure in the glove box 👍🏻
Running E5 Momentum 26.4 mpg (thinking about it I had an E46 M3 that wasn't much worse) 20 miles past zero on the range and lots of shortish local town journeys and managed 47.77 litres to fill.
First tank, mixed fuel of whatever dealer put in and rest filled with momentum 99, 24.7mpg, mainly urban runs with traffic.
I'll find out soon enough, but can anyone with experience of comparing winter to summer mpg on the GR give an estimate of the loss in colder months? In my turbo'd other car it's about 20% so just wondering if the GR will fare worse (probably depends on what portion of journeys are carried out where the engine doesn't have chance to get up to temp).
The label inside the fuel filler says e5 and e10
A lot of it depends on the driving conditions and style.
My mpg kept gradually increasing as I approached the first 1000 miles and an oil change, but as the weather improved and I completed the break-in procedure, my driving style adjusted accordingly, and with it the fuel consumption. I'd imagine it would be the same for most owners here.
Perhaps someone who commutes on the same route every day could give a more accurate answer to this.
Driving on E5 exclusively , A and B roads with mixture 30,40,50 and 60mph with some spirited driving thrown in, I get indicated 33mpg in summer and 30-31mpg in winter. This is over around 6000 miles traveled.
No problem with 95RON as per above.
My MPG is likely to fall after this evening as I crossed over 1,000 miles and switched the 4,000RPM warning off 👀
SWMBO is going into hospital in Mcr for around 4 weeks on Friday so the mileage will be a fair bit higher by the New Year I expect
I treated the car to a tank of premium fuel this morning… But it’s nice to know that I can alternate if needed and it won’t impact on the warranty
Best wishes to Mrs Bluemanc
