GR Yaris Powerflex engine mount insert
Fu Manchu
Tried to fit the powerflex black Powerflex Black upper engine mount insert and after 2 hrs of toil, I've given up.
Is there an easy way to get the insert fitted?
What trouble did you face? Have you watched the Tegiwa video?
I've got mine to do and think its seem pretty easy - now I have my doubts!
The thing that I had a problem with was getting the powerflex black mount to open enough and squeeze under the bracket to fit it to the mount.
The Tegiwa video uses the yellow versions which are softer.
I don't remember exactly how I did it, but the black one is a real bitch to get in place. I was struggling to get it on for a good while. I think I ended up using a flathead screwdriver in one hand to help bend it over.
Ahhh! I see.
Let me know if you manage to succeed! πŸ˜πŸ‘πŸΌ
I've managed to get this sorted.
The Tegiwa YouTube video is good for showing the process but uses the yellow bushes which are quite a bit more pliable than the black versions.
In this instance, a mixture of heating the new bush in hot water for 5 mins, washing up liquid on the rubber part of the engine mount, a metal trim tool to guide and put pressure on the bush + the powerflex instructions (https://www.powerflex.co.uk/i/product_images/76-925 FI-min.pdf) and a lot of brute force, it will go in πŸ™‚
Notice any more vibrations?.
I ended up having to saw a notch into mine to get the damn thing to fit lol. Good work (y)
