The thing that I had a problem with was getting the powerflex black mount to open enough and squeeze under the bracket to fit it to the mount.
The Tegiwa video uses the yellow versions which are softer.
Ahhh! I see.The thing that I had a problem with was getting the powerflex black mount to open enough and squeeze under the bracket to fit it to the mount.
Notice any more vibrations?.I've managed to get this sorted.
The Tegiwa YouTube video is good for showing the process but uses the yellow bushes which are quite a bit more pliable than the black versions.
In this instance, a mixture of heating the new bush in hot water for 5 mins, washing up liquid on the rubber part of the engine mount, a metal trim tool to guide and put pressure on the bush + the powerflex instructions (https://www.powerflex.co.uk/i/product_images/76-925 FI-min.pdf) and a lot of brute force, it will go in![]()
I ended up having to saw a notch into mine to get the damn thing to fit lol. Good workI've managed to get this sorted.
