ctecperformance
Devoted member
- Nov 1, 2023
- 95
- 170
The UK OEM plug is NGK DILKAR8U7G heat range 8. If you want to run one heat range cooler you need to go heat range 9. The higher the HR number, the cooler the plug heat rangeIt’s 9
I went 8 because I wanted to try colder plugs as I’m running more boost and our fuels in Aus seem of questionable quality at times
