JT99
Fascinated Member
Hi all,
Had Pearl for two weeks now and loving the car but a couple of days after collection from an independent car supermarket, my wife and I went out to the car with one of the fobs in hand and were uable to unlock the car using the fob. The LED on the fob lit every time the unlock button was pressed but nothing happened. Thinking that the battery in the fob was flat I ran inside for the other key and all was well with our journey. When we returned home I tried the first fob again, and again no luck with remote access. I took out the physical key and tried it in the door lock. We were shocked to find that it didn't even turn the lock. We took out the second fob's physical key and tried that one knowing that the fob was working correctly and the car was opened using the physical key. That indicated to me that the fob and key were not matching i.e. I have some else's second key!! I took a picture of the physical keys side by side.
As you can see the keys are cut completely different so realistically this means the keys are for two cars. I have taken this up with the selling dealer who is ordering a fresh remote fob and having the physical key cut then the fob will be reprogrammed for me. My local Toyota dealer tells me that this is not an uncommon thing where fobs do get mixed up. The cost of a new key supplied, cut and programmed is £690 so not a cheap fix. My concern is that someone else out there with a GR86 may have my second key and if you hide your second key away and only use the one it may be wise to check and see if your spare works correctly as some other owner may have the same problems that we had.
Stay safe JT
Stay safe JT
