GR86 Owners - Check Your Spare Key!!!
JT99
Fascinated Member
East Lancs
Hi all,
Had Pearl for two weeks now and loving the car but a couple of days after collection from an independent car supermarket, my wife and I went out to the car with one of the fobs in hand and were uable to unlock the car using the fob. The LED on the fob lit every time the unlock button was pressed but nothing happened. Thinking that the battery in the fob was flat I ran inside for the other key and all was well with our journey. When we returned home I tried the first fob again, and again no luck with remote access. I took out the physical key and tried it in the door lock. We were shocked to find that it didn't even turn the lock. We took out the second fob's physical key and tried that one knowing that the fob was working correctly and the car was opened using the physical key. That indicated to me that the fob and key were not matching i.e. I have some else's second key!! I took a picture of the physical keys side by side.
As you can see the keys are cut completely different so realistically this means the keys are for two cars. I have taken this up with the selling dealer who is ordering a fresh remote fob and having the physical key cut then the fob will be reprogrammed for me. My local Toyota dealer tells me that this is not an uncommon thing where fobs do get mixed up. The cost of a new key supplied, cut and programmed is £690 so not a cheap fix. My concern is that someone else out there with a GR86 may have my second key and if you hide your second key away and only use the one it may be wise to check and see if your spare works correctly as some other owner may have the same problems that we had.
Stay safe JT
My dealer rang me up later on the day I collected my car, saying they thought they'd given me the wrong key as another customer had two different keys, but in my case both my keys were correct. A few days later got a call from Toyota online asking me to return to the dealer for the same reason. So someone else out there obviously has a mismatched set too.
Our car was registered in Jan 23 by main dealers in Brighton so might have been mixed up then?
JT
Hi all,
View attachment 25817View attachment 25817
Stay safe JT
Ha! Exactly the same thing happened to me at the end of October. I'd had the car a month before I tried the 2nd key and I was baffled for a while before I tried both small metal keys - then all was clear. I took it back to the dealer and it took six weeks and three prompting from me to get a replacement. I thought this was just a one-off, but clearly not. It shows security and handling systems leave a lot to be desired at some dealerships.
Dealer prep nowadays is truly shocking... The dealerships I worked at back in the day would have seen the techie in the offfice after a key mix up like that, as it's part of the PDI to check all keys and locks berfore handing to sales..In fact the sales guys I knew were red hot at finding stuff like that in order to score points against the workshop lads!
Just don't get me started on fitting number plates straight😤
JT
