GR86 One for all GR86 Owners: PCV Valve
When I took the old one off there was a bit of RTV around the threads. So I just used a bit of PTFE tape.
Also, when I screwed it back in, it doesn't sit full flush with the block...at least it didn't when I had it tight enough that I didn't want to torque it further. Hoping others have found the same, although so far no leaks.
Not sure I would want the risk any of that tape falling down the threaded hole when you come to remove and replace the valve in the future.
Happy to hear others views.
This, although it shouldn't disintegrate, so if you're careful it's not usually a problem
For those who have done this, are any of you putting ptfe or liquid ptfe on the threads or is it simply screw off and fit the new one. Got it to day, £14.03 and they were very good. Even gave some Subaru branded biscuits for the dog.
I did not put any kind of ptfe liquid, also the is only 22nm , but keeping an eye if any oil or residue leaves the area keep an eye for it time to time .
I’d be inclined to use a small amount of Hylomar near the top of the thread.
It’s officially like a vent so there shouldn’t be too much oil get near it.
Amayana got back to me. There's no stock at the supplier, so it's .5 - 1.5 months delay. Then the time it takes to ship it from Japan.
Sigh. It I want to change it anytime soon, looks like I'm going to have to pay Toyota's extortionate rates. I suppose I could save myself £15 quid by going to the nearest Subaru dealer, but it's a 100 mile round trip, which at today's fuel prices means I probably wont make any saving and will take a few hours out of my day.
Honestly, **** Toyota.
Want me to see if my local Subaru dealer can source another one and I can pop it in the post? They only had a couple left last week from central stock.
That's very kind of you, but I've ordered two from Teqsport in the US now. Ordering two works out at about £15 each, so only a quid more than the Subaru dealer anyway. Thanks anyway.
I've ordered a bunch of bolts and fittings off Amayana for my GT and stuck a pcv valve on the order as I'd figure id check it and it'd be cheaper with delivery already paid etc... stuck on "ordered from supplier" FFS...
Before I ordered two from Teqsport yesterday, I also fired off an enquiry to Japanparts for that part number. Didn't expect an answer for a while, but they responded this morning and are now listing it :)
It's currently listed at £5.61, but delivery is £22.61. So even if I ordered two, it works out just slightly more than Teqsport anyway. However Japanparts are pretty good for all sorts of stuff so it's useful to be able to get it from there...maybe you can tag it onto an existing order if you're shopped for something else. Always good to have more options.
Those of you who changed your PCV valves, have you noticed any change in how the car actually drives?
It might be in my head, but since I've cleaned the OEM one and put it back in, I feel like the low speed driveability is a bit smoother...that weird way the that the throttle feels a little dead right at the top seems better. And I think that the jerky kangaroo throttle, that a fair number of us have noticed when accelerating from low revs, is a bit less pronounced. Wonder if a sticky PCV valve affects the intake pressure or something.
Still yet to change it but yet to drive it since either. Shamefully not driven it since April but was down to work on the house, busy on other things, bee 💩 in the work car park so I do t want to commute in it if I can help it. I thought I'd ring Toyota again to see what process is for warranty. All diagnostic work is chargeable at £135 an hour and that valve may not be covered anyway. They weren't sure. If I just wanted them to change it, they have it down as 2.1 hours to do. To change a £15 part. If the pipe wasn't hard to get off it takes 10 mins! Beginning to wonder why I'm bothering holding on to the warranty when it's a scandalous service cost and you still pay through the nose. Might be time I find a good indy and go from there.
man really 2.1 hours????
I must admit was hard to remove the pipe but nit more than 20 min of work at most , after doing the last service on Toyota Hedge end got nothing to complain to be honest next one will be at Abbeymotorsport i can do myself but they are experts in this cars so want their opinion.
Belive said on previous post is hard to remove the pipe the rest is piece easy and then you learned a new skill
I'll probably make the trek to Abbey or Fensport (there was someone else but I forget) or I could try Garage Whifbitz as they do a lot with Jap cars and isn't that far. Near the bridge.
Didn't see this. I'm fairly certain after changing the car is smoother in lower RPMs, namely idling.
Once the pipe is off it's a really quick job. Honestly, it does feel like Toyota take the p*** a bit. Makes me think after 5 years I might forget the extended warranty and look at FI with servicing from someone like Fensport.
Would you be charged those 2 hours or is that just how long they want it for?
They'd need time for the car to cool and some time to check it's working fine after fitting. If it's meant to have any sealant on it, then it'll be an hour before starting it up again.
Changing the oil pressure sensor is similar, takes a few minutes to remove and screw a new one in, but engine's gotta be cold, book says an hour for sealant to set etc
is ok 1 hour seallen so pay for peaple to sit while sealint is setting of?
i work in aviation while sealing is going of i am doing other jobs .
