GR Yaris Octane booster for the GRY to bring 95 RON petrol to 98 RON
Spirited
The manual states "Do not add aftermarket fuel additives which contain metallic additives...for example manganese, iron or lead, otherwise it may cause damage on your engine or emission control system."
Also, I understand one needs to be cautious with definitions and claims about octane boost, as for example octane is not the same as octane point, etc.
Any octane boosters suitable for the GRY, to give us 98 RON in the tank when only 95 RON is available at petrol stations?
For reference, the Torco Accelerator contains Manganese. I would love to know what this may actually cause (ie is it indeed engine damage or eg a sensor/cat fault), but "manual says no".
Don’t waste your time, just stick in a splash of 95 until you can fill up with 98 again. Absolutely no harm will come of using 95.
From the manual:
Just to add, because this is in the same manual seven pages later... I have no idea why they've split this information up into two places, but there we go.
It's not helpful in the same manual they don't mention that it may reduce output, or knock, if you're on 95.
I'd suggest probably don't beans it on 95
If the engine management didn’t have to reduce output for lower octane fuel, it would make the existence of higher octane fuel largely redundant.
95 RON is for bingo chariots, and Range Rover Sport drivers who can’t afford to run a Range Rover Sport. Performance car engines are designed to run on higher octane fuels.
If I can’t get hold of V-Power I just try and coast home, avoiding the brakes at all costs, and straightlining roundabouts (rally suspension really helps here).
Performance matters.
I'm pretty sure dealerships didn't always/usually/ever fill their demo cars with 99 RON fuel - especially if the nearest garage was a Morrisons supermarket.
They still seemed to run well on full beans! 🤣
Yeah, I asked when I picked mine up... he pointed inside the fuel flap saying it could run 95. Sadly, he didn't seem aware about the whole should be running on 98 thing. The funny thing is the fuel station that's closest to them is an Esso, which sells 99.
Pro boost was always very good
Thank you, I'll have a look!
I know when I picked mine up, it had a quarter of a tank in it, but also that it was from Morrisons, as I had access to MyT.
They got the oil wrong with people who had theirs serviced at that dealership before I got my car, so I did expect them not to have bothered putting in 99 RON - so a good thing they only put in a quarter of a tank?
I drove mine around the Highlands on 95RON for a week. No knocking or really obvious change in performance. I would always use 99RON now where possible and wouldn't be sticking additives in there for normal road use, where there was a shortage of the latter 99RON.
Christmas time for two fill ups, I couldn’t get 99, I had to fill up on 95. Seemed to go the same but a noticeable drop In mpg over the same mundane trips to work
OP I’m also Hampshire based had my car 26 months and 20,000 miles and driven up to Scotland twice and around Europe 2/3 times and have yet to have an issue getting 98+.
Or, if like me your partner worked in a refinery fuel additives laboratory, just get some toluene 😈
On my round the Island trip I was in the North of Aus unable to get anything other than 91 Ron on several occasions. I used Nulon octane booster that gives about 7 Ron increase and had absolutely no problems with ‘ pinking ‘ The car is quite capable of detecting pre ignition and retards the ignition instantly.
When using 95 octane the car ran happily but it Instantly showed a drop in expected tank distance from 550km to 500km so extra Ron is worth the money! For track day use adding octane booster might well increase top end performance.
Thank you! I'll check it out.
I haven't been able to get an 98/99 RON fuel for a number of weeks. Nowhere in south Manchester seems to have any & I have seen various posts in other groups suggesting that this is all over the North West. I am assuming that there must be some kind of production issue? 🤔
The refinery closed for a maintenance shutdown. No issues down south as supplied from Fawley.
Stanlow refinery in Ellesmere Port was supposed to shutdown for maintenance in September for 9 weeks, and it will have done this previously. However, I have never noticed not being able to get 98/99 RON previously in over 20 years of living in the North West & have always run my cars on this stuff. Hopefully normality will resume soon.
