warren_RS3
Dedicated member
- Apr 20, 2022
- 103
- 203
I had a similar issue to this on another car. It turned out to be a traction related issue. If there was any traction issues the cars default position was to cut the boost. The car ran very high tyre pressures and had staggered tyres, neither of which helped, and seemed exacerbated if there was any steering angle. If I turned TCS off fully it almost completed remedied the issue. It can be so difficult trying to pin these issues down to a sensor, a mapping table issue or operating anomaly. I’m not saying it is this issue, but just widening the points for consideration.
Ideally if someone could log boost requested vs actual, see whether there is any timing pull, and monitor whether any sensors are operating outside of expected values it would be a good starting point. No known issues with diverted valves holding pressure like on the VAG early valves with rubber skirts?
