Well it's only on one side, some small marks inside the wheel house. I never noticed it while driving.Interesting that you get rubbing - I have 8.5 ET38 which is within 1mm of "poke" of a 9 inch ET45 and no rubbing so far with 225 tyres and 2.25 degrees of negative camber.
Rear I think you will be OK, specially if you go for 245 section tyres . You may have issues at the front with the oem shocks and springs.Got a set of used 17x9 +42. I will be testing in the upcoming weeks, concerned about the rear fitment. May require rear camber, in this case would rlca or ruca be better?
I heard about that, coilovers are next. May have been a better plan to start with coilovers, but I found a good wheel/tire set for a fair price.Rear I think you will be OK, specially if you go for 245 section tyres . You may have issues at the front with the oem shocks and springs.
Rlca are easiest to install but they push out/ pull in the wheel from the botton, Ruca does it from the top.
If you don't need more negative camber than the oem setup, I would install the wheels and test if they rub before changing suspension parts
I believe the small TPMS warning light would be an MOT failure.If I don’t swap the TPMS off the oem wheels, the warning light is just one of the small lights right and doesn’t hide the vehicle information like it does when it thinks the pressure is low?
Edit: just checking as Toyota have quoted £702 and my first born for another set plus coding…
WTF?! Daylight robbery! You can get a brand new set of sensors for around £100 online and get them coded at your local independent wheel shop.Toyota have quoted £702 ... for another set plus coding…
Confirmed. I bought OEM from Toyota - they need codingToyota was £200 for a full set but they'll need coding. They claim not but I don't believe them
Did you get them to code them or somewhere else?Confirmed. I bought OEM from Toyota - they need coding
Lovely.Finally got and fitted my NT03RR's on Saturday, thanks for all the help from the people on here given I was asking some pretty stupid questions.
17*8 ET48. Pilot Sport 5's (225/45/17). It might be a placebo but the road noise doesn't seem as bad with these so far.
Need to lower the car a bit now but I want to sort out getting the TRD kit first.
View attachment 30291View attachment 30292View attachment 30293
Sorry just seen this, they are Hyper Silver and I got them from Torque GT. Depending how the light catches them they go from being a kind of quasi-chrome silver to quite a dark silver.Lovely.
Which colour are thiose and where from if you dont mind
