KobayashiMaru86
Not sure if is still the case but some insurers if it's brand new, for the 1st year payout the full new value.
Lauren's is the only one I can think of and they were probably after the YarisI can count on one hand the number of Gen 1 cars that have been reported stolen on the forum/facebook in the 9 years I've had mine. Two of these were because the thiefs were targetting another car the owner had.
They are the wrong sort of car / not valuable enough to be a target. I'd be more concerned about vandalism than theft, even then my concern is extremely low.
I’ve used ALA several times over the years. Really good team there and very helpful.
If enough are interested they will likely sort us out a good discount for the site.
TBH they are the only company I’ve ever used![]()
I always take out GAP but it won’t be any help getting a new 86 should something happen!
Considering additional CCTV and trackers for security
So I notice on ALA's key facts sample doc that some of the restrictions are:Garage and GAP from ALA for me too. MSE25 always used to get you 25% off the online price.
Yes, exactly this. GR86 is a poor car to steal really. Having a Disklok as a visual deterrent is a good idea and boxing the car in with another car is always a good idea. You could also add a Ghost. I would also say never leave your keys downstairs and have them in a secure place. The more difficult you make it to nick, the harder it is.Lauren's is the only one I can think of and they were probably after the Yaris
Yep. Best cover for reasonable £TBH they are the only company I’ve ever used![]()
A Disklok would be better though wouldn't it? It would also negate the need to faff with velcro.If anyone is considering getting a steering wheel lock then here's a pic of a Stoplock Pro Elite in a GR86 - I tried the cheaper Pro version but couldn't get it to fit (not enough clearance between it and the horn). I wrap a length of double-sided velcro around the steering wheel rim and the Stoplock arm to hold the arm clear of the indicator stalk.
Thanks for sharing, I've also bought the same steering wheel lock, so good to know it will fit okay.If anyone is considering getting a steering wheel lock then here's a pic of a Stoplock Pro Elite in a GR86 - I tried the cheaper Pro version but couldn't get it to fit (not enough clearance between it and the horn). I wrap a length of double-sided velcro around the steering wheel rim and the Stoplock arm to hold the arm clear of the indicator stalk.
I have a Disklok in my GRY and it's great, but it's a hassle to get on/off, so decided to go for the Stoplock for the GR86 which I intend to use more often day-to-day than the GRY.A Disklok would be better though wouldn't it? It would also negate the need to faff with velcro.
I use a Small for the GR Yaris, so should fit fine in the GR86.I'm probably getting a Disklok. Presumably it needs the small size?
Yes, it is a bit of a faff, though I use it only when I'm at home. No need when I'm elsewhere.I have a Disklok in my GRY and it's great, but it's a hassle to get on/off, so decided to go for the Stoplock for the GR86 which I intend to use more often day-to-day than the GRY.
What annoyed me is that these things are built like tanks, and I've marked my steering wheel when opening/closing the disklok - this is with the steering wheel cover on too!Yes, it is a bit of a faff, though I use it only when I'm at home. No need when I'm elsewhere.
This is what I'm also doing now, cheers! Extra piece of mind to have these fitted [emoji106]I have the pro elite, i have the lock part top right and the yellow end sits nicely in the gear gaiter, takes 5 seconds to fit so i use it everywhere
