Spirited
- Jan 23, 2022
- 488
- 504
I have a yellow-series Powerflex front engine mount insert fitted. My driving has been as per its intended use, ie fast road, not track. I've had no complaints since I fitted it together with its yellow sibling for the upper gearbox mount and a DNA Racing fast road torque mount (which uses Powerflex purple polyurethane).
I noticed that the zip tie that holds the front engine mount in place has given up. I've also seen reports of the same insert coming out if it's place despite not using the car hard. So, I guess that's a realistic risk now for my situation but in any case the inset isn't held in place as its manufacturer designed it to be.
I'm happy with the slightly yet noticeably increased NVH of this set up, so I'm concerned about potentially introducing a black insert at the front engine mount, as:
- It will mean a different hardness rating in each of the three bushes I have currently
- I will be installing the Powerflex caster kit (front wishbone rear bush) which is likely to introduce some NVH anyway (so, probably don't need any more)
- Not sure if replacing the yellow with a black Powerflex insert resolves the issue of this insert's zip tie giving up.
