GR Yaris Front engine mount insert Powerflex
Spirited
I have a yellow-series Powerflex front engine mount insert fitted. My driving has been as per its intended use, ie fast road, not track. I've had no complaints since I fitted it together with its yellow sibling for the upper gearbox mount and a DNA Racing fast road torque mount (which uses Powerflex purple polyurethane).
I noticed that the zip tie that holds the front engine mount in place has given up. I've also seen reports of the same insert coming out if it's place despite not using the car hard. So, I guess that's a realistic risk now for my situation but in any case the inset isn't held in place as its manufacturer designed it to be.
I'm happy with the slightly yet noticeably increased NVH of this set up, so I'm concerned about potentially introducing a black insert at the front engine mount, as:
  • It will mean a different hardness rating in each of the three bushes I have currently
  • I will be installing the Powerflex caster kit (front wishbone rear bush) which is likely to introduce some NVH anyway (so, probably don't need any more)
  • Not sure if replacing the yellow with a black Powerflex insert resolves the issue of this insert's zip tie giving up.
@MarkoS if you have a similar setup to what I may soon be having (ie DNA Racing fast road torque mount, yellow Powerflex upper gearbox mount insert, black Powerflex front engine mount insert & a caster kit), please let me know:
  • how it all works in terms of NVH once the various bushes have had a few miles to bed in; and
  • if the black insert destroys the zip tie.
Thank you!
your post now reminds me to check that cable tie, odd design relying on cable tie to secure an engine mount, so does the black insert also rely on the cable tie?
have to say having driven a colleagues factory car recently it felt super smooth id forgotten how buzzy those powerflex are, going black is probably best left to harcore track users
initial I thought the cable tie was just to keep it in place while installing hence e why I've never checked it, but if you think it's full time needed I'll look to replacing mine as with the constant hot/cold cycle they go through bound to fail eventually
Indeed, it is to keep it in place full time, not just during instalation.
I think there may be an option to use two zip ties, maybe 1 cm apart from each other, by the looks of it.
Some have had to replace the zip tie repeatedly and others tried steel zip ties, but I'm not going there.
gonna take close look at this, proper faff to keep replacing 2p cable tie to stop an engine mount failing, what kind of design is that.
so do you need to take insert completely out to re-tie it ?
... proper faff to keep replacing 2p cable tie to stop an engine mount failing,...
On the bright side (kind of) another user posted that it won't ever pop out completely. However, not much point having it in if it's not working as intended. Plus having a loose zip tie there, if/when it breaks, can't be good.
Do I sense a bit of optimism bias, here? 😊Are you hoping for an easy job? It might be possible, as the instructions on https://www.powerflex.co.uk/product-details/Upper+Engine+Mount+Insert/14099.html show the zip tip to be fed once the insert is already in. The problem is:
  • Access might still be tricky to be able to pull the broken one out and feed the new one in;
  • I was probably wrong about the possibility of putting more than one zip tie slightly apart from each other;
  • Is it worth the hussle and/or cost...?
Thank you!
Hello!
There is quite some NVH compared to stock (if I even remember correctly the stock NVH). You can feel the car vibrating when stationary, mostly on the floor through my feet since I switched to rubber mats. I do feel the stock seats make up for the most of added VH, so it doesn't feel bad. Make sure your rear license plate doesn't hit the tailgate while shaking. On a scale 0 (stock) to 100 (track weapon) I'd place it mid 30s - low 40s ;)
The zip tie is still in place, going to the mechanic today probably so will take a better look on all the inserts /mounts then.
