It doesn't....Doesn't do a lot for the anxiety levels, does it?
Seems a very good reason to keep the warranty up or to do some preventative work.
I was thinking that it had been opened if it had a baffled sumpDon't believe him, RTV is not the problem
He raced that car in the ring multiple times, he starved the engine of oil as he is not sympathetic to cars, he has said it himself, he is not a mechanic but a driver....
Overfill a bit, oil cooler and a sump baffle is what the GR cups run and they have been completely fine
He had also already opened the sump to put that baffle in so shouldn't be complaining about the oem RTV.....
The problem with preventative work is that most of the works would give Toyota a reason to invalidate your warranty. So you are in a catch 22 situation.Doesn't do a lot for the anxiety levels, does it?
