CerN
- Feb 17, 2023
- 336
- 1,096
This is what I have also understood, after watching some Japanese YouTube videos on the topic, with automatic dubbingOn this topic Litchfield aren't responsive, so i'm health checking my own logs for piece of mind.
- Knock Correction Angle, which appears to be the instantaneous knock response from the sensor. The EcuTek dev car has always been based around -3deg and it counts up until it commits that increase into the Knock Correction Learned parameter, when it resets to -3deg and continues to measure knock sensor output and correct the ignition. tis value can be changed, if set to 0 it wont add ignition only ever remove it.
To be clear i've understood -3 is no correction needed. Anything lower e.g -3.1 means real time correction based on possible knock. When this gets down to -4 it starts committing to long term correction. Same applies in the upward direction -2.9 & up gives you timing advance. -1.9 starts adding timing to the long term stored number.
Is that accurate yes/no?
The max value for the long term stored number is 24.1, and below 18 it starts to seriously reduce performance. As far as I have gathered, you want to be sitting in the 20+ range.
