GR Yaris Apex Yaris has thrown a valve rocker again
Don't think I will be loosing any sleep over this. The Apex car must spend most of it's time being tortured on the ring. Be interesting to see what the mileage is?
Agree with most that im sure the valvetrain is up to the job for general application
That said, Rent4ring used to run swift sports that are capable of this (including at least one 1500rpm over rev) -
With literally half the power (150 bhp) going through four cylinders and 16 valves.
Now I sound like I’m being defensive!
I just think this is a bit of a non-story. But it is good click-bait and they are running a business, so crack on.
I’m definitely biased because I own a couple but I think it’s pretty impressive that a warm (at best), budget hatch is able to reliably run the Nurburgring like they have for years, without much required other than basic maintenance
I think they’re great cars. Similar power and weight to a Clio Williams. I would happily own a Swift Sport.
I was just making the point that it’s producing 37.5 bhp per cylinder, rather than 100 bhp+ per cylinder. So it’s not nearly as stressed.
There’s 15,000+ G16E-GTS units out in the world now, many of which are being thrashed on a daily basis, and many others used in Rally1 etc. There are going to be some units that fail, particularly ones that are driven flat out around the world’s toughest ‘circuit’ by people who would rather not destroy their own cars.
Surely there will be zero G16E-GTS engines in Rally1.
Well, it's nice that the guy can now be confident it was not his fault, it's just that the valvetrain is inadequate.
There’s 15,000+ G16E-GTS units out in the world now, many of which are being thrashed on a daily basis...
Good points, was thinking the same. Also, without overreving (sure?) there are very little if any failure reports and objectivly speaking, one possible alley of investigation into a damage like this is most definitely previous damage and repairs...
I do wonder if there are really more than 15k G16E-GTS engines made, haven't seen numbers of the 1.5 atmo cvt version, word is they sell quite a lot of those too...
Earlier rumours said about half of the production was CVT so around 15k sounds plausible. But the production of the GR Corolla should increase the number considerably over time I guess?
Hi, this reply may upset or offend many GR Yaris owners.
My understanding is, this car was built for rallying. If I'm wrong then please correct me.
Yet we seem to just want to take them on track days, which is not what the car was developed for.
I'm sure someone will come back and ask "are you going to take yours rallying" the answer will obviously NO. But I will be driving as many tight , undulating country roads as possible. I'm sure I will encounter tractors, twitchers and lycra louts but I will drive within my limits and respect all others on the road .
If I've offended anyone, I'm sorry.
Why would that offend anyone? Some people do track days, some people don’t.
Everyone who does regular track days is aware of the extra wear and tear it puts on the car. If you look after it, warm it up, cool it down, keep oil levels up and change regularly etc, you don’t expect the engine to go pop after a few thousand miles though. And I don’t think that’s happening, despite what Apex are making out. It’s a modified Nurburgring hire car that receives a lot of abuse, and it’s suffered from valve float on the stock valve springs, which are known to have a low spring rate.
Being pedantic, it’s not a rally car, it’s a rally homologation car, that only required the bodyshell to be fit for rallying. But it does (optionally) come with a ‘Circuit Pack’ in the UK.
Taking it rallying without modification would certainly test its durability. I’m not sure it could complete a single stage without being smashed to pieces. This applies to any Impreza, Evo, Integrale road car. Their suspension is set up for fast road use, which happens to make them pretty decent on a typical track day too.
This is probably how most will be driven. (y)
Agree on the first bit, but this passage is short changing the GRY but also Evo's and Subies. In the past the latter were used i rallies with very minimal mods and faired fine. There is currently a GRY only rally series in Italy and Netherlands/Germany (?), again with not many mods.
And the GRY (not the bodyshell only 1.5 CVT) has actually been developed with tarmac and gravel use in mind and as pointed out before, 'Circuit pack' is marketing and is called 'Performance pack' and even 'Extreme Rally' in other markets. GRMN is available as a track and as a gravel special. We are a few in Scandinavia that most definitely push our cars a bit on gravel roads too.
A GRY is a suited to a rally stage as, roughly, e.g. a Megane RS Cup is suited for trackday duty and the odd race (not being F1 material doesn't mean it doesn't do a track). The GRY engine was designed from scratch with use in rally applications in mind too and was passed by FIA for approval for what is now Rally2/3 use as a 3-pot, albeit allowing changed valvetrain amongst others.
Some vids showing some rally prowess out of the box:
(some fun but there is underlying substance)
https://www.rtl.de/videos/gute-kraf...lye-qualitaeten-60ec668ba9112874f7734d52.html (competitive time on rallycross track dispite road tyres)
Much left on the table but basic prowess is again there
Sorry bit off topic but like to put 'just a bodyshell' narrative in context...
Tarmac rally stages = racetrack. But this is a moot point since a stock GRY is neither a real race car or a real rally car as some already has stated above.
Not equal. Track often much smoother excluding steet circuits such as Nurburgring. But yes its not a race car as registered street car vs racecar is completely different animal
Not wanting to drift too much from the original premise that an n=1 / one car used as a Nurburgring rental car is somehow an example for failures in Toyota valve spring design. I agree that the GRY is not really a track car at all, despite most of the sales being for the Circuit pack. It does this well but it is designed to traverse poorly surfaced undulating narrow roads/tracks at high speed, ideally in poor conditions. It does this really well. Although a bit too much grip in summer - so use the sport / 30/70 mode.
Have there been any valve spring failures in standard non-modded cars not taken on a track?
The racetracks here in Sweden are not smooth at all. Some have huge jumps too. So I stand by my statement 😁
Another track 😁
A couple of tracks have very bumpy straights, fun in the braking zone 😜
Edit: sorry for going off topic.
