GR Yaris 50-130km/h Acceleration Leaderboard
New personal record🎉 5.43 seconds.
Again 1/4 tank (V power, not changing a winning team here) and sitting on my own in the standard car except the DTUK, but this time map 3 + 2.
@ Onehp I might just keep my OPF😉
OK, finally got my Dragy (I pre-ordered the latest version) and am ready to join in.
Who knew finding sufficiently flat bits of road was such a problem? 😁
Anyway, managed a few 50-130 runs just running about today, the best of which is a 6.17s
Only mod is a DTE v1 box running a dynamic the sport map. The Dragy and the DTE apps don’t seem to play well together i.e. I can’t check the DTE map at the time as it doesn’t seem able to use Bluetooth at the same time as Dragy.
Edit: running on V-Power 98, about 90% full tank, no passengers
Only mod is a DTE v1 box running a dynamic map. Don’t know which one as the Dragy and the DTE app don’t seem to play well together i.e. I can’t check the DTE map at the time as it doesn’t seem able to use Bluetooth at the same time as Dragy.
Hi Duke,
Great to see you joined in and thanks for sharing!
Indeed it is a pain to switch between both boxes everytime you switch maps, even though the phone does keep a connection between the both of them.
Same here, it’s difficult to keep track what map you’re in when trying out several maps.
I actually sent a mail to DTE and asked if it was possible to make their app suitable for Carplay. They replied by confirming the idea is great and actually tried to make that work, but Google and Apple are not willing here unfortunately.
Ps There might be some room for improvement since your tank is 90% full. If you would do the same run with 1/4 tank you would save about 25 kg’s. That said, it sure is a lot to ask of the engine over such a full range. So no need to actually try this, unless you want to of course😉
Yeah, it would seem to be the perfect CarPlay application!
Re-reading this thread it would be nice to see what @Phil1291 is managing now that he's gone banzai 😁
Okay, found a perfect bit of road and did a few runs.
Best was a 6.06 in Sport, with a few more around 6.1s. Did just fill up though so this was with a pretty much brimmed tank.
Will get the updated DTUK map and see what difference that actually makes.
Good Job, Marco. (y) Because i have not change anything the last 10 Month, my50-130 Time will stay the same with my Car: 5.89
OK, got the updated DTUK V1 map and took advantage of quiet roads on a national holiday to put in a few more runs. Still no other mods, full tank 🙄 of V-Power and an 80kg driver with an ambient temperature of 15°C. Did two runs on each setting, with a cool down cruise between each pair.
Still can’t crack the magic 6 second barrier 😡😂 but inching closer. Best was a 6.02 on Sport +2, but I managed runs within 0.02s on all Dynamic or Sport settings so I think we can say that, for the purposes of long pulls like this, the mode makes very little difference.
The new map does seem to have marginally improved all times, but that could be differences in temp or fuel on the day.
Actually, looking at that run, maybe I lifted a little early… 🤔
Edit: for reference, did some runs with the box off, here's the summary
Stock: ~6.40s
Original V1 DTE map: ~6.10s, with a best of 6.06s
Updated DTUK map: ~6.05s, with a best of 6.02s
Just ordered one :cool: what's the current board look like? is there some way to keep it updated?
Edit: for reference, with the box off I was seeing times around 6.4s
Besides a better time to previous runs/different maps, I noticed you also have an upslope of approx +.2%. The other run was a downslope of -.3% So compared this run differed by 0,5% upslope ánd a better time!
If you would empty your tank a bit I think there is a good change you break the 6 sec barrier👍😃
It is a corrected 6.00 👍🏻.
Sport mode, all off, 1/4 tank Shell 100, no mods, first try.
Good run👍🏼
By the looks of the first one…you might get a better time if you start your run a little earlier so the turbo has had some time to spool up. If you would start around 40km/hr you would see a steeper line in the beginning.
Good run👍🏼
Your car looks like very brisk. Wonder if MY23 cars have revised head (from Corolla)? would explain the difference.
That time seems in line with my stock runs
Changed to an Eventuri inlet and set a new personal record 🎉@ 5:31 with an outside air temperature of 15 deg Celcius.
Even though I was able to run it in map 2 + 3 the car was not faster. The fastest runs where made in map 2+1.
In order to keep an easy track of specs:
-'21 Circuit Pack
-std wheels
-DTUK V2 (map2+1)
-OPF/GPF delete
-driver weight 90kg
-1/4 tank V power
-'21 Circuit Pack
-std wheels
-DTUK V2 (map2+1)
-OPF/GPF delete
-driver weight 90kg
-1/4 tank V power
When was your car made? And how fast is it without dtuk?
I do not know exactly when the car was build. She was first registred jan ‘21. But according the VIN it’s an early one: #3105.
In the past I did do a few runs with the DTUK off and that resulted in approx 1/2 sec slower (compared to the config it was in at that time). This was done when the OPF was still in place and also the std airbox (+ std filter ofcourse).
Ok thanks. Mine is also approx 0,5s faster with HJS/IC and less then 0,1bar boost add sub 6k rpm.
So all that makes sense.
What doesn't is that your (early) car is so f****** fast 😬. Maybe it was mapped before without your knowing? It has happened before...
My early car (#2349) did a 6.33 run with GPF del / Milltek exhaust - otherwise stock. So everything below 6s is really good for a stock car as you said.
