GR Yaris ๐Ÿ‘Ž Negatives - what annoys, disappoints, puzzles and generally irks you about the GR Yaris?
Bloody engine doesn't start with the door open :mad:
Thats a good thing. Earlier this year someone started a caterham in the paddocks at Goodwood whilst stood outside. The car was in gear and off it went with no one in it.
I had a Harley that did similar.
I reckon I could have challenged Usain Bolt if I'd had to sprint after it, but with it being a Harley I didn't have to run that fast.
The beeping from the cruise control when you go down a hill.
Can I turn the beeping off?
Yes so annoying and doesnโ€™t seem to be any consistency. Some steep hills the cruise seems to control the brakes and then other more gentle hills it struggles the Speed Runs away and then beeps like mad.
Reactions: Gyp
Yeah, but we already have to have foot on brake and clutch to get it to start so that's never going to happen in a GRY.
Interesting. I use cruise control all the time and never had a beep.
Yeah I thought that as the dash icon shows both pedals. Try starting the car with just the clutch depressed next time.
Not sure why it shows that as Iโ€™ve never pressed both just clutch.
You need a downhill section or you can activate it by accelerating whilst still on cruise I believe. You should get a white box around the set speed as well.
Go drive the A68. It's like a rollercoaster. It'll beep all the time.
Or... if you've managed to turn it off some how... please tell us how!
I get the white box but no beep.
I turned off a lot of things with Carista soon after getting it. Maybe it's one of those.
Yes. It's in the dash menus. Never had it on in all honesty. Asked the dealer to turn off all possible beeps when I picked my car up. Isn't the beeping a speed warning?
the image is trying to imply its clutch OR brake but most think means both, just needs one pedal depressed
I've never ever started an ICE without depressing the clutch as it take good amount of weight off the starter motor not having to spin up gear box cogs in cold oil
Just tested this, this morning and it is the clutch you have to press, just pressing the brake will not allow the car to start...
Not sure why they show both pedals, but i guess pressing both also allows the car to start!! ๐Ÿคฃ๐Ÿคฃ
back in the old days car could be moved with the starter motor, starting in gear.
In case of being stuck on railway crossing with faulty engine it could be useful treat. But Toyota trusts its engineering that much that it has been skipped from the feature list.
what section this is more spesificly ? this is annoying and will turn it off from both our cars. glad its selectable
If you are talking about what I think you are it is the overspeed tolerance on cruise set speed. You will need to navigate through the menus because it is 2 years since I did mine. And that was about 5km from the dealer on the side of the road with the sales guy talking me through the menus! I asked for everything to be off but I think they forgot or it was policy to leave all that annoying shit on. Being told to obey road rules everytime I went over the limit had already worn me out!!
