Then it's different from my car, led on means there are two (=dual) climate zones active. Perfectly logical.For the left hand knob the green LED is on when the ‘Dual’ function is off???!!!
I’d never thought of it like that but I can now see your point.Then it's different from my car, led on means there are two (=dual) climate zones active. Perfectly logical.
When the left led isn't lit, the right knob controls a single temperature for both sides. When it's lit, there are two zones, left controlling left and right controlling right.Just a minor point of amusement/bafflement. The air con controls.
When the green LED for the right hand knob is on it means the ‘Auto’ function is on.
Err...When the left led is lit, the right know controls a single temperature for both sides. When it's lit, there are two zones, left controlling left and right controlling right.
Err...
Have you disabled ESE?The audio in the car sounds dreadful..no matter what settings you try ...
I'm going to add the stop start.
I know a lot of people hate stop start and turn it off every time they get in to a car with it, but I have no objection to it in principle. I have it on my Skoda DSG and it's totally fine and unobtrusive.
The GRY is the first manual car I've had it on so my "new" problem might be something others have been aware of for years.
When I want to pull off, dip clutch, engage gear and start to apply the accelerator as the clutch pedal comes up and I release the handbrake. But the Yaris doesn't react quite quick enough, so the engine isn't quite up to speed so it stalls.
Muscle memory kicks in so I dip the clutch and hit the starter button to restart the engine, except because of the stop start the car still thinks it should be running and tries again to start the engine just as me hitting the button has actually turned the car off.
At which point I have to keep the clutch down and hit the button to restart the car again...
Typically this only happens when I'm at the front at the lights (not unusual in the Yaris) so I hold up a line of cars behind me. If I'm a few cars back, I react more slowly dipping the clutch and selecting the gear waiting for the car in front to move.
It's the tiniest of frustrations and something I have to learn (I currently disable start stop if I'm at the front of the queue), but the 5 seconds or so of messing about feels like a lifetime of embarrassment.
A Feature or function that's in a car should work as intended. If you like it keep it on, if you don't switch off. But a Feature or function that's faulty or doesn't work as intended, it's definitely a negative thing to point out. Solid valid fact to point out in my opinion.Why aren't you disabling it every time you get in. I do that even before.y seatbelt is on.
A agree with a few respondants like this one - Nothing wrong with Start/Stop in principle. It's just that Toyota's implementation is so bad. I had it on my Peugeots and would never had thought about turning it off. On the GRY it's the first button I press after start - thinking of putting a sticker over the dash though cos the light for it is so stupidly bright.I turn it off every time I get in. I think it maybe related to the clutch bite point but I've stalled too many times using it. Not had such problems in Fords I've driven recently like the Puma ST where it works perfectly well with a manual powertrain.
Just stick it in Sport. This disables stop/start but doesn’t show the dash light.A agree with a few respondants like this one - Nothing wrong with Start/Stop in principle. It's just that Toyota's implementation is so bad. I had it on my Peugeots and would never had thought about turning it off. On the GRY it's the first button I press after start - thinking of putting a sticker over the dash though cos the light for it is so stupidly bright.
