GR86 Battery Dead after 1 night
Taggy
Anybody have there battery die after just one night of non use? Car parked up the previous evening completely dead by the following evening ... Battery has always worked perfectly before this and has held a very good charge. Any ideas to the cause welcome (keys were in there usual place) plus good aftermarket battery alternative would be great . Thanks Taggy
Do you have any 3rd party electronics attached to it? i.e. Dash Cam, Tracker, Alarm, replacement head unit etc.?
If not then I'd take it into a garage (unless you or someone you know has a clamp meter or something similar to check yourself) to see what the current drain is when the cars totally off (i.e. give the car 5 minutes after off for the various systems to shut down and time out).
*edit* I just googled this page randomly from the internet, but from a quite gaze the advice is sound
https://drivesmarttools.org/car-battery-current-draw-when-understanding-parasitic-drain/
Never after just a single overnight. Most I’ve left the car off my ‘Noco Genius 10’ optimiser is 3 days and it did show a tiny ‘drop’ on the optimiser charge leds when I next connected it. Not sure how indicative that is though.
I have a BlackVue 4k 2ch Dashcam with parking mode (have set battery monitoring on), a 24/7 live tracker and a Ghost immobiliser - all of which draw parasitic current whilst the engine is off.
For confidence I replaced the OEM Panasonic 48Ah Battery with an identical dimensioned ‘Bosch S4025 60Ah/540A’ (also lead acid) prior to the car’s 6m Winter storage last year. No issues to date.
No after market devices the car is completely standard - anybody going with anything that isn't the old lead acid type ?
It is very unusual for battery to just fail. But it has happened before. I would recondition/replace battery first, before diving into gr86 charging circuit and measuring drain. Quick google shows similar issue with one person on Pistonheads, but treads stop before resolution.
Had you left your internal light on (the dome light/map light)? That’s caught a few of us out.
I have read about it multiple times in the German community. There are several similar cases where the battery was suddenly dead. The cause remains unknown, but it seems likely that a module is not shutting down properly when this happens.
The original battery is also of questionable quality. I've already replaced it because I had trouble with it.
The new one is a Exide EL604 EFB battery (60Ah 520A). And just to be on the safe side, I always carry a jump starter with me now.
Me too, but only when I'm on a longer trip. Mine is the 'Noco Boost X GBX45', which is suitable for up to 6.5L Petrol and 4L Diesel engines. It also acts as a power pack for recharging/powering USB devices.
Not on this car but I have had a battery go kaput out of nowhere before, I think its rare, but does happen.
As for a replacement, it has to be Yuasa for me. The GT86 was notorious for having a terrible battery from the factory, not helped by the Sigma alarm being power hungry, mine gave out after 2.5 years, I fitted a Yuasa YBX3014 and that was still going strong when I sold it in 2022.
When my car was relegated from daily duties I fitted a battery monitor, less than £15 and 15 minutes to fit.
If you dont already, when you lock the car, switch off the keyless sensor for the car. This saves a lot of battery usage. I used to have the odd low power battery, not enough to start the car and since switching off keyless when parked at home, I haven't repeated the issue.
Keyless off: when you press lock on the remote, press unlock twice in quick succession whilst holding down lock. Check to see it has been set by using the door handle to see if keyless entry still works. It takes a few times to get it right sometimes but it will switch off.
@ninjin This only puts the key into a standby mode so that its wireless part no longer responds to the car. The manual also clearly states that this is meant to extend the battery life of the key if it is not being used for a longer time.
For the car it makes no difference. Its keyless system is still fully operational. Grab your second key and you will notice that the keyless entry still works.
Thx for the clarification, I always thought it switched off the keyless system on the car side.
