- Jan 23, 2022
- 488
- 500
- 93
So, I understand that this is a different "product" to the initial warranty and comes with its own terms and conditions.
In the UK too, one of these stipulates parts & fluids used, including engine oil, to be Toyota. That's OEM, not just as per to Toyota spec. Not entirely sure if this also means "provided by the dealer", but this is the least of my worries.
I may even be able to stomach using Toyota engine oil, if its labels adhere to what's on the engine oil cap, despite this essentially meaning that I will be paying more for less, ie inferior quality compared to the best aftermarket ones.
I need to clarify if using aftermarket parts or fluids invalidates the Relax warranty for that area of the car only or as a whole. Ie, if I use an aftermarket rear diff oil, do I lose the warranty for the rear diff or for everything the Relax warranty covers.
Thank you @Armijs for bring this to my attention through your posts:
Switched the ledbar button to a more aesthetically pleasing one:
In other news: We had TOP MEN visiting from Toyota Baltics yesterday, and we got the following run down, outside of standart warranty, which is 3 years or 100 k km mostly, when TOYOTA RELAX warranty starts, we can ONLY service the cars with TOYOTA fluids, all oils, brake fluid, cooling fluid, because if something happens to anything be it engine, brakes, whatever outside of standart warranty and the client or us have not been using Toyota fluids or parts, filters as well, the RELAX warranty will...
Yes, and also only Toyota manufactured/marked oil, we had a meeting recently, and without beating around the bush, Relax warranty will only be honored if every maintenance is all Toyota OEM parts/liquids, oil included, that is why for further...One of the first things they do in Toyota Europe when having engine problems is to take a sample of the oil in the engine and do an analysis…if the results show that engine is not within 0w20 specs, then whatever happened is not under warranty. So changing to 5w30 oil (or any other, for that matter) means losing your warranty, basically.
