Long overdue update, albeit without anywhere near as much to report as last time.
Car has now just ticked over 16.5k miles, still basically faultless.
Latest additions to the car are:
- Godspeed front big brake kit
- Goodyear Eagle F1 Assymetric 6 tyres
- Swapped from original M2 Motorsport seat bases to PCI Racing bases
Godspeed brake kit was fitted today by my friends up at Tuning Developments in Chester. So far, so good. Braking performance, at least initially, doesn't feel massively different to stock (which is good, no relearning how to heel-toe), but as you get further into the pedal, you get a lot more bite and confidence from these new brakes.
For those unaware, the new Godspeed kit consists of a set of Renault Megane RS Brembo calipers, 330mm discs, a choice of pads and all brackets/bolts required. I went with Performance Friction Z Rated pads, a popular choice in Renault circles, alongside the floating disc option and some Motul RBF660 fluid. Calipers are also finished in something called "Ski Doo Yellow", the closest single stage paint I could find to the Renault Liquid Yellow-esqu colour I've tried to go with across the various yellow accents. Godspeed were kind enough to have these powdercoated for me at no extra cost, which was very kind.
My only slight annoyance currently is a grinding noise from the outside wheel when at full lock (so left wheel when turning right and vice versa). I'm sure this is just a shroud or dust shield or similar, but no major concern for now. Doesn't make any noise under normal driving, just low speed and full lock. (If anyone has any ideas, I'm all ears, but I'll get it looked at ASAP).
The tyres seem to be a fairly positive experience too. I was running a set of Continental SportContact 7s in 225/40, which lasted me around 12,000 miles. They were exceptional, but if anything, too grippy for this chassis (at least for my driving style). They were also fairly loud, and had quite a stiff sidewall.
On the flipside, initial impressions after around 400 miles on the Goodyears are a significant reduction in road noise, a slight improvement in comfort, but at the expense of that ultra responsive initial turn in the Contis offered. I don't necessarily see this as a downside though, as I found the Contis ultra responsiveness did kind of cause me to move about a fair bit in the seat. These slightly less responsive tyres almost give my body a chance to brace for turn in beforehand, so in a weird way, the car feels like it rolls less (when it perhaps would roll more on a softer sidewall). Weird, but interesting.
As for the seat bases, a typical experience of buy cheap buy twice. I had a great deal on the M2 rails, under £200 for the pair (a welcome offer after the expense of buying the seats). Their design however, being so massively adjustable, meant it was borderline impossible to get them fitted correctly. A constant bug bear. After weeks of frustration, constantly taking the drivers seat out to adjust (I think I counted around 20 times in a month), I got annoyed enough to spend £330 on a single base for the drivers side, and a good decision it was.
Anyone thinking of changing to bucket seats, just don't bother with anything other than the PCI bases, I can't see how anything would be better.
Anyway, enough rambling, a few pics:
