GR Yaris DTC fault codes P030100, P030200, P03000, P030027
After two weeks of hell trying to find why my car kept getting CELs and fault codes P030100, P030200, P03000, P030027, I finally have the answer:
The dual mass flywheel has failed and causing changes in crankshaft speeds and/or the knock sensor was hearing strange noises. The dampening in the flywheel has failed completely.
Clutch assembly & flywheel replaced with an NPC single mass flywheel. I'll have to put up with the annoying noise between 1500 & 2500rpm that the dual mass flywheel concealed.
out of curiosity, could you hear this noise (as in your video) when driving slowly releasing the clutch for example ?
Generally, when a dual-mass flywheel fails, you start getting a "clunk" at throttle-on and throttle-off. If you hit a spot where the engine is neither "pushing" nor "pulling" the drivetrain, it can rattle.
heard a random clunk when doing third gear pull on sunday evening - hope it was not a flywheel. but now we know what defect codes to search for that issue, good post!
thanks. so it doesn't seem to far fetched to create this "clunk" by stepping on the clutch
