After two weeks of hell trying to find why my car kept getting CELs and fault codes P030100, P030200, P03000, P030027, I finally have the answer:
The dual mass flywheel has failed and causing changes in crankshaft speeds and/or the knock sensor was hearing strange noises. The dampening in the flywheel has failed completely.
Clutch assembly & flywheel replaced with an NPC single mass flywheel. I'll have to put up with the annoying noise between 1500 & 2500rpm that the dual mass flywheel concealed.
