- Dec 27, 2021
- 1,775
- 2,946
You're selling because of the flimsy grille?Put my plate on retention today
Pretty gutted tbh but once the grille’s replaced & I’ve put it in for its first service it will be going up for sale.
That’s a big part of the reason, yes - if there was a sturdy aftermarket alternative (or if the replacement cost wasn’t so much of a piss-take) I’d have probably kept it.You're selling because of the flimsy grille?
If it had broken in a neat square like Lauren’s, I might have been tempted to leave it a bit longerNot fun when small stuff breaks, but in the end the car is for driving not for looking at it while squatting in front of it.
Will replace costlier body parts first when stuff starts falling of, or when selling up. Will kit a metal finer grille on the inside when bumper comes off, simple measure, mostly for protecting the IC from bigger stones (that also ruin the grille)...
A man after my own heartFortunately i am blessed with the "could not give a monkeys chuff gene" with regards to what it looks like cosmetically....
Take one look at my 'one careless owner' Mini GP, for proof, although i do look after them mechanically you will be pleased to know!!
Hence my road grime black paint job!! It helps hide the scratches...
I had an alternative thought.One potential way to 'fix' it is to cut out all visible plastics but keeping parts outside of vision, and then glue all around (using sikaflex or similar) a metal mesh of choice in place. Might leave a gap but if you are handy/patient, metal mesh can be bent to counter that too?
Yes/no?
Sounds good but I'm not very handyOne potential way to 'fix' it is to cut out all visible plastics but keeping parts outside of vision, and then glue all around (using sikaflex or similar) a metal mesh of choice in place. Might leave a gap but if you are handy/patient, metal mesh can be bent to counter that too?
Yes/no?
Your choice, but that seems a rash decision. I lost a slat due to impact damage from debris on the motorway, but have now done nearly 21K miles. No more damage to the grill. I just don't worry about it. You could put a mesh behind it which would give it a bit more strength perhaps?That’s a big part of the reason, yes - if there was a sturdy aftermarket alternative (or if the replacement cost wasn’t so much of a piss-take) I’d have probably kept it.
Aside from not doing much driving in it to date, looks likely that I’ll do even less soon as I’m picking up a van on Saturday to go cruising/camping in.
I will be bloody sad to see it go though.
I get the feeling people getting tired of the GRY....
Having hit a fox and a been in a Cadillac Escalade which was written off by a deer, I don’t expect any grille to withstand the impact. Isn’t it attached with a couple of screws so they’re your weak spot.at least it should keep the foxes out
