KobayashiMaru86
I'll check what's left in the 1ltr but pretty sure they've put 5.5l in. Then over the year I think I added 200ml
To come back to this, this time they've only put 5l in. The 1l is untouched as was the last one in the boot. very odd. Checked levels and is OK.I'll check what's left in the 1ltr but pretty sure they've put 5.5l in. Then over the year I think I added 200ml
Had a super weird coversation with the dealer. Supplied 5L of oil and they kept saying 5.8L is needed. Somehow 5L is only on the minimal line?
This is the third time I have changed my oil + filter, and have always found that 5L for oil + filter change is enough as stated on the user manual
I dunno have they been drinking my engine oil for fun or something. Or Toyota have sent a note to overfill by 0.8L...
I checked the oil level today, cold, it had been stood for a few weeks.I changed the oil myself at 1600 miles, after reading many online posts saying 5 litres.
5.0 Litres barely filled it to the minimum mark and leaving plenty of time for it to drain into the sump didn't change that.
Luckily I had bought another litre for top ups, it ended up with another 0.6/0.7 litres to bring it closer to the max mark.
Concerned by this, I later found info saying 5.5 litres for oil and filter change, but can't find it now.
Starting off at the minimum after an oil change isn't a good idea, it will only go down from there.
Next time I'll know I NEED to get 6 litres and only have a small amount left.![]()
Any material or advice I can point to that will get them to budge?
.. or the option is just not available on the computer screen they have in front of them.If you want more detail or to venture off piste they dont have the time for it.
As the oil level gauge is used for daily inspection, standard of “F” line and “L” line of the oil level gauge is set for the condition that engine is cold.
The ones I've had from Subaru were dry.I did mine last night, 110miles. At Snetterton next weekend so thought Fresh oil would be beneficial.
I can confirm "stuff" came out, there were lumps in the previously clean oil pan, I've not looked further to confirm what it is yet. Terrible picture for reference!
One question, I'm doubting myself... Typically Toyota oil filters all come with a plastic wrapper over the business end, and a gasket that is pre lubed for easy install/sealing.
As such when doing the Hilux I never "pre lube" the filter gasket. On my other cars I use k&N filters, I need to put a bit of oil on there as they arrive "dry".
Last night when doing the GR86 I pulled off the wrapper and installed and can't remember if I checked if it was pre lubed or not... Can anyone confirm if it is or isn't?
Genuine Toyota boxed, Subaru filter from Fensport.
Yup,The ones I've had from Subaru were dry.
Think you want to be topping up your oil asap thoughJust done over 8000 miles on ours and noticing oil consumption is high(its making its way to the min level far quicker than any other vehicle I've ever had)
