GR86 Mudflaps
Saha
Absorbed member
Hello
Are the mudflaps available yet for the Gr86.Thanks
Hello
Ordered mine 21st September and still not arrived at dealer. Bluemanc100 has email to say his will arrive in stock 27th October. So I’m hoping mine will be in then too.
Thanks
Automotive passion ones are now available.
I'm quite tempted by those. I currently have the OEM mudflaps, but I suspect the AP ones might actually be slightly more effective and at the same time, less obvious.
And I'm not sure I would miss having the mudflaps on the rear...my main concern is about keeping stone chips off the side of the car and from keeping the leading edge of the front sill getting peppered and possibly rusting. I'm less worried about the rear bumper as it's plastic.
EDIT: Bugger, the normal plastic ones are on backorder. Not a fan of carbon fibre trim :/
I ordered some yesterday, so I'll report back on how effective they are. I'm not too fussed about the rear bumper either, and they're less likely to cause issues with the paint on the front compared to the OEM ones potentially rubbing or trapping dirt.
I’ve got some but the car they were going on has gone back 🙄. Replacement incoming though. I’ve used these before on a previous vehicle, had bought front and rear but only got round to fitting the front. Pretty effective without looking too much like mudflaps so have got similar expectations for these.
I've also placed an order. My plan was to sell on my OEM set. But annoyingly, I've just remembered...I had to drill two small holes on the inside of the rear arch in order to fit them. Hopefully not massively obvious once they're removed, but still unsightly. I'll have to see if I can find a plastic plug or something to close them up. The hole on the underside I'm not too bothered about, it won't be visible unless you lie under the car.
Hard to tell from the pics, do they still let air through the vented section? Are they held in place just by the oem mounts holding the arch liner?
The photos aren't very good but it will be like these for the M2 and are likely not to obscure the front vent.
Reactions: JDS
I noticed this after ordering. There are 2 actual holes in the vents and it looks like they block there bottom one. I might see about cutting out a hole for the bottom vent if there's enough width in the material to still give the mid flap strength.
Automotive passion reckon you could, but have said the vents aren't functional and just help much get thrown down the side of the car.
Reactions: JDS
FYI, from the European press release.
A series of aerodynamic features has been introduced, including a front air dam and fully functioning air vents, created with TOYOTA GAZOO Racing’s motorsport expertise. These are located behind the front wheel arches to manage airflow and reduce turbulence around the tyres, enhancing steering stability.
That's what got me thinking about putting a cutout in, and I'm still leaning towards doing it. I'll get them fitted as-is first and then see about taking a Dremel to them.
