Ordered mine 21st September and still not arrived at dealer. Bluemanc100 has email to say his will arrive in stock 27th October. So I’m hoping mine will be in then too.Hello
Are the mudflaps available yet for the Gr86.Thanks
ThanksOrdered mine 21st September and still not arrived at dealer. Bluemanc100 has email to say his will arrive in stock 27th October. So I’m hoping mine will be in then too.
Here’s the link I used to order them:Hello
automotivepassion.net
Yes. My dealer got them and fitted.Hello
Just the fronts?Automotive passion ones are now available.
Toyota GR86 Arch Guards/Mudflaps
Stone chips can cause unsightly damage to ones car! Give you Yaris GR paintwork the protection it deserves!automotivepassion.net
Brilliant!Here’s the link I used to order them:
https://toyotadirectparts.co.uk/parts/toyota-gt86/toyota-gr-86-mudflap-front-and-rear/
Afraid so. They didn't have suitable mounting points for the rears, apparently.Just the fronts?
I’ve got some but the car they were going on has gone backI ordered some yesterday, so I'll report back on how effective they are. I'm not too fussed about the rear bumper either, and they're less likely to cause issues with the paint on the front compared to the OEM ones potentially rubbing or trapping dirt.
Hard to tell from the pics, do they still let air through the vented section? Are they held in place just by the oem mounts holding the arch liner?Automotive passion ones are now available.
I've also placed an order. My plan was to sell on my OEM set. But annoyingly, I've just remembered...I had to drill two small holes on the inside of the rear arch in order to fit them. Hopefully not massively obvious once they're removed, but still unsightly. I'll have to see if I can find a plastic plug or something to close them up. The hole on the underside I'm not too bothered about, it won't be visible unless you lie under the car.I ordered some yesterday, so I'll report back on how effective they are. I'm not too fussed about the rear bumper either, and they're less likely to cause issues with the paint on the front compared to the OEM ones potentially rubbing or trapping dirt.
The photos aren't very good but it will be like these for the M2 and are likely not to obscure the front vent.Hard to tell from the pics, do they still let air through the vented section? Are they held in place just by the oem mounts holding the arch liner?
I noticed this after ordering. There are 2 actual holes in the vents and it looks like they block there bottom one. I might see about cutting out a hole for the bottom vent if there's enough width in the material to still give the mid flap strength.Hard to tell from the pics, do they still let air through the vented section? Are they held in place just by the oem mounts holding the arch liner?
FYI, from the European press release.I noticed this after ordering. There are 2 actual holes in the vents and it looks like they block there bottom one. I might see about cutting out a hole for the bottom vent if there's enough width in the material to still give the mid flap strength.
Automotive passion reckon you could, but have said the vents aren't functional and just help much get thrown down the side of the car.
