AndyRC
I got a reg off a car and used that , sadly the parts are very expensive
I am currently on Endless MX72Plus all round and new high temp fluids now. Massively improved the brake feel (much firmer pedal with less travel, braking power very adjustable with pedal pressure alone), will need to test it on track but do expect it to survive 15 minutes sessions fine.Anyone just upgraded pads yet? I want something that will work well for light track use and general fast road driving.
Also, am I right in thinking that any post 2017 non-Brembo equipped GT86 pads will fit just fine?
I'll probably go this way too. What was your fluid preference? How much does it need?I am currently on Endless MX72Plus all round and new high temp fluids now. Massively improved the brake feel (much firmer pedal with less travel, braking power very adjustable with pedal pressure alone), will need to test it on track but do expect it to survive 15 minutes sessions fine.
@Will300 the Reyland CP9200 you are using on your gt86, is it bolted or floating?
Guessing floated?
@Will300 what's the clearance like with those wheels, and do you think that kit is likely to clear most 17 inch wheels as well?Bolted - As I didn't want the extra NVH that floating give, they were cheaper to purchase and its cheaper to just replace the bolts when replacing discs.
Awesome, thanks for the info. Have you upgraded the rears as well or are they stock?Barrel clearance is extremely good. Offset clearance is very good, the only wheels I'm aware of with issue are the stock GT86/BRZ (Gen1) wheels, as it requires a spacer. It's probably the most common (UK) kit for the Gen 1 cars, so plenty of people have used them with lots of different wheels.
The smallest wheel I personally tried is a 17x7 +40.
Where did you order the pads from?I ended up going for PFC Z-Rated and Motul RBF660 fluid, booked in to be done next week. I'm at Brands Hatch Indy on the 29th so I'll let you know how I get on.
ETA: You should need just under 1L @KobayashiMaru86 - I ordered 2x 500ml bottles of RBF660 from Opie Oils. Use discount code GET10 too, although better voucher codes may be floating around too.
How do they perform from cold ? Is it possible in your opinion to run those pads as dual track/street pad or would you rather swap them in before track days (noise is my last concern) ?I went with Ferodo DS1.11 all around and Motul RBF660.
It’s definitely possible and I will do it sometime when I’m too lazy to change back to stock pads. They work very well to brake the car from cold but they do make some more noise depending on how much transfer layer you have. They will also be quite abrasive on your discs if not up to temp but luckily discs are pretty inexpensive.How do they perform from cold ? Is it possible in your opinion to run those pads as dual track/street pad or would you rather swap them in before track days (noise is my last concern) ?
