Great news fellas!! The MAF sensor is held in place by two torq’s bolts. They need to be carefully tightened.
I just checked them today and they were coming loose. So I took a torq-bit and using two fingers tightened them again. On the second bolt the whole mounting cracked and came loose. So either I have superhuman strength or the mountings is way to fragile.
I can’t drive with air coming in after the filter so the car is basically scuffed. Will need to remount original box and return the broken one. Should be a warranty thing, right?
I've ripped-out that lower plastic grid+sound-dampening cloth on mine since new... no issues noticedI'm not a tømmerhugger or a hand-oriented weightlifter. So I cant be the only one.
Contacted the Norwegian vendor and they in turn will contact Forge. I will have to change to standard and then change back, but as I said to the Norwegian vendor: I dont really like the thought of having components under my bonnet that can be cracked by pianofingerpower. Will see whats what.
Quick question though: When I removed standard upper box I did not manage to remove the silencing inside the box with the pop-socket-things intact. Will there be any sort of issue running normal box without the sound deafening thing in the bottom?
Also running without sound deadening here - no issues..I'm not a tømmerhugger or a hand-oriented weightlifter. So I cant be the only one.
Why did you remove that hose thing? Is that what controls the flap that opens? I haven't removed that.I've ripped-out that lower plastic grid+sound-dampening cloth on mine since new... no issues noticed
Aftermath of the Forge air intake duct install:
my reasons:Why did you remove that hose thing? Is that what controls the flap that opens? I haven't removed that.
Is it an easy to restore mod (flap removal) or does it involve ripping up some glue bond or the like?my reasons:
1. upon Forge carbon air intake scoop install, the lower end of the airbox (also) gets fresher/denser air - which in my opinion defeats the purpose of having the flap system.
2. Sound... this can a minus if you prefer to have a quieter intake.
3. Simplicity...
Interested too, tried removing mine, felt solid in there.Is it an easy to restore mod (flap removal) or does it involve ripping up some glue bond or the like?
my initial plan was just to "unhook" the flap... forced a bit too much and BANGIs it an easy to restore mod (flap removal) or does it involve ripping up some glue bond or the like?
I guess it would benefit the car a bit. On the other hand, I've got plenty of boost and low IAT anyway below 4k rpm (where the flap opens), I'm thinking I'm fine as is, and driving sub-4k rpm would appreciate the slightly quieter intake sound.my initial plan was just to "unhook" the flap... forced a bit too much and BANGThe flap + its plastic support completely detached from the airbox - a bit of a scary moment really! No turning back after that - since the support seems to be glued (maybe ultrasonic welded) to the airbox.
Anyways, I guess there are good offers for used lower air-boxes in case one wants to re-install the flap... which I don't!
The "positive" side of that is there's now a wide opening pointing to the front/forge scoop.
Another data point, MST lost power mid range vs stock.
To avoid any douby, I'm not Jesse. He has a few interesting vids but as I said, one data point only but as he has the integretity to give the bad news, perhaps a *good* one data point!Very well done. You're one of the first
Stock airflow is very good, but IAT on the other hand is aweful. Personally I've seen 80C, neary same scenario with @Helmut Eder scoop was 30C lower.
I testet it in PETG!![]()
You made great work for giving this intake to others, but for the sake for those who are planning for this reading here, we have now two cases where the intake melted/deformed with PETG from the thread 'What did you do to your GR Yaris today?' here and here, so maybe you should update material recommendations on the file share.
