I think it's nearly impossible to avoid. On my GT86 I was meticulous with the diamond cut wheels and they were regularly coated and cleaned but eventually all of them have suffered white worm. Its a lovely finish but flawed by design.Thank you. So chrome is a finish applied to a wheel, and moisture can get behind it. I (probably incorrectly) thought that diamond cut wheels had the metal cut and polished, so there wasn't a finish applied for the moisture to get behind?
Thanks. What lacquer should I buy to look after them?My 1997 Diamond Cut alloys are pretty good, there is one small chip but I got lacquer on it in time and it hasn't got worse., but bear in mind i am only doing about 500miles a year in and normally in better weather. I find best to wash the, little but often with just car shampoo and never use harsh wheel cleaners, this also helps.
There’s was a set on eBay for £1200 up until a week or two ago.How much is a realistic price to sell the original wheels for, if sold with just delivery miles?
And the same for the tyres
Thanks
Just one single now, link below.
@WWGR86 great choice, the sl’s look so good against the white. How are the hipermax’s for comfort with the pillowball topmounts on the front?Here is my stock replacement setup.
Rays Volk TE37SL Face 4
18 x 9.5 +45
245/35/18 Michelin PS5
HKS Hipermax S coilovers - 25mm lowering on front , 26mm on rear.
Have not done alignment yet - only on natural camber.
No rubbing so far.
It sits on perfect for me. Dream spec.View attachment 19272View attachment 19273View attachment 19274View attachment 19275
HKS made a great suspension for road. I am now on 18 clicks from the stiffest and it is very comfortable and better ride quality than stock.@WWGR86 great choice, the sl’s look so good against the white. How are the hipermax’s for comfort with the pillowball topmounts on the front?
TC105X and T66F was also on my list but cannot resist TE37SLs which are discounted. Lucky enough to find a set of second hand.TE37’s are lovely, has them in the past and would be on the shortlist for the 86 (albeit not in white, never again!!) That aside I’ve seen Advan RZ2, Wedssport tc105x and TWS T66 compliment the car well depending on colour and specs fitted.
Lovely wheels, my favourites.Here is my stock replacement setup.
18 x 9.5 +45
No rubbing so far.
