foxspeed
engine oil & filter capacity - 4.3ltr (4.0ltr without filter)
engine oil spec - SAE 0W-20, API SN Plus or SP (plain SN is Supra spec), ILSAC GF-6A
08880-83885 (1ltr bottle)
08880-83886 (5ltr bottle)
coolant capacity - 5.2 L
coolant type: Toyota Super Long Life Coolant” or
Similar high-quality ethylene glycol-based non-sili-
cate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology
Do not use plain water alone.
Spark plugs: DILKAR8U7G
Gap: 0.7 mm Use only iridium-tipped spark plugs. Do not adjust the spark plug gap.
gearbox oil capacity - 2.1 L (with LSD), 2.0 L (without LSD)
gearbox oil spec - “TOYOTA Genuine Manual Transmission Gear Oil LV GL-4 75W” or equivalent
transfer box oil capacity - 0.45 L
transfer box oil spec - Toyota Genuine Differential gear oil LT 75W-85 GL-5 or equivalent
rear diff oil capacity - 0.5 L
rear diff oil spec - Toyota Genuine Differential gear oil LX 75W-85 GL-5 or equivalent
Clutch fluid spec - “TOYOTA GENUINE BRAKE FLUID DOT4, CLASS6”, FMVSS No.116 DOT4 or SAE J1704LV
Brake fluid spec - “TOYOTA GENUINE BRAKE FLUID DOT4, CLASS6”, FMVSS No.116 DOT4 or SAE J1704LV
wheels - 8Jx18, ET45, Centre Bore 60.1mm, PCD 5x114.3,
wheel bolt torque - M12x1.5, Torque 103Nm
tyres sizes - 225/40 ZR18 92Y
tyre pressures - Front 2.2 bar (32 psi) | Rear 2.0 bar (29 psi)
Colour codes (UK)
089 Platinum White Pearl
3U5 Scarlet Flare Pearl
040 Pure White Solid
219 Precious Black Metallic
Wheel Specification
8Jx18, ET45, Centre Bore 60.1mm, PCD 5x114.3, Lug Nuts M12x1.5, Torque 103Nm
Tyres 225/40 ZR18 92Y
Yaris & Convenience Pack - Enkei Cast alloy weight 10.5 kg
Circuit Pack - BBS Forged Alloy, weight 8.2/3 Kg
tyre specs
Yaris & Convenience Pack - DUNLOP SP SPORT MAXX 050 (225/40 R18 92Y) 9.7kg
Circuit Pack - MICHELIN Pilot Sport 4S 225/40-ZR18 92Y 9.5kg
Colour codes (UK)
Wheel Specification
tyre specs
