GR Yaris GR Yaris Technical Data
foxspeed
sat behind a laptop moderating
engine oil & filter capacity - 4.3ltr (4.0ltr without filter)
engine oil spec - SAE 0W-20, API SN Plus or SP (plain SN is Supra spec), ILSAC GF-6A
08880-83885 (1ltr bottle)
08880-83886 (5ltr bottle)
coolant capacity - 5.2 L
coolant type: Toyota Super Long Life Coolant” or
Similar high-quality ethylene glycol-based non-sili-
cate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology
Do not use plain water alone.
Spark plugs: DILKAR8U7G
Gap: 0.7 mm Use only iridium-tipped spark plugs. Do not adjust the spark plug gap.
gearbox oil capacity - 2.1 L (with LSD), 2.0 L (without LSD)
gearbox oil spec - “TOYOTA Genuine Manual Transmission Gear Oil LV GL-4 75W” or equivalent
transfer box oil capacity - 0.45 L
transfer box oil spec - Toyota Genuine Differential gear oil LT 75W-85 GL-5 or equivalent
rear diff oil capacity - 0.5 L
rear diff oil spec - Toyota Genuine Differential gear oil LX 75W-85 GL-5 or equivalent
Clutch fluid spec - “TOYOTA GENUINE BRAKE FLUID DOT4, CLASS6”, FMVSS No.116 DOT4 or SAE J1704LV
Brake fluid spec - “TOYOTA GENUINE BRAKE FLUID DOT4, CLASS6”, FMVSS No.116 DOT4 or SAE J1704LV
wheels - 8Jx18, ET45, Centre Bore 60.1mm, PCD 5x114.3,
wheel bolt torque - M12x1.5, Torque 103Nm
tyres sizes - 225/40 ZR18 92Y
tyre pressures - Front 2.2 bar (32 psi) | Rear 2.0 bar (29 psi)
Colour codes (UK)
089 Platinum White Pearl
3U5 Scarlet Flare Pearl
040 Pure White Solid
219 Precious Black Metallic
Wheel Specification
8Jx18, ET45, Centre Bore 60.1mm, PCD 5x114.3, Lug Nuts M12x1.5, Torque 103Nm
Tyres 225/40 ZR18 92Y
Yaris & Convenience Pack - Enkei Cast alloy weight 10.5 kg
Circuit Pack - BBS Forged Alloy, weight 8.2/3 Kg
tyre specs
Yaris & Convenience Pack - DUNLOP SP SPORT MAXX 050 (225/40 R18 92Y) 9.7kg
Circuit Pack - MICHELIN Pilot Sport 4S 225/40-ZR18 92Y 9.5kg
USDM GR Corolla g16e-gts only call for API SP ILSAC gf-6a ... someone said that earlier yaris were spec'd to use ILSAC GF-6B before... as in 0w16! is that true?
also do you guys put LT (non-LSD) gear oil in the transfer but LX (LSD) gear oil in the diff? I usually use redline but amsoil also specs transfer and diff as the same fluid for their off the shelf stuff. thanks
Tme are
Tme are now listing 0w-16 for the gr Yaris along with 0w-20 don't know the exact sub spec as couldn't make it out from where I was sitting when they showed me the listing for it but I'd certainly keep to 0w-20 on the corolla as if the engine was able for it also they would have listed it off the bat.
Not true
I used LX in both although I know it isn’t necessary for the transfer, neither can I see it doing harm.
Colour codes (UK)
Wheel Specification
tyre specs
In Europe, they put GR Supra oil in my MK2, saying it's the only one they give... I looked and it has API SP specifications... but it's not GF6A... could it be that harmful? I read that SP protects against LSPI.
Wrong oil I believe.
Dealers here use the Toyota 0W20 AFES (08880-83590 - out of the 208L drums)
API SP with Resource Conserving matches ILSAC GF-6A by combining API SP performance with improved fuel economy, emission control system protection and protection of engines operating on ethanol-containing fuels up to E85.
Mine will be without catalytic converters, I don't have e85 and I don't care about saving fuel... so is API SP ok? 😂
I don't know... in my opinion it's not 100% his... but it's superior to the one used on mk1 which was API SN+... that's why I doubt it could work anyway... if not a Pakelo?
Mk1 was always SP/GF6A 0w20
