JJ.King
Absorbed member
- Apr 23, 2023
- 43
- 35
**Bold text are the questions**
Hello everyone, I’m confused with what and how to install the Shifter Base Bushing. (The Shifter cable I know is straight forward)
I’ve had a few friend install the lamspeed billet shifter cable AND the shifter base bushing. However they told me they only did the top bushing for the shifter base. (Refer to diagram below)
After looking at limited YouTube videos and other limited sources on how to install this, I’m confused, because I see people changing both bushes (Upper and Lower). My friend swears by the difference without changing the lower bushing along with a few others who haven’t changed the lower bushing.
So my question is, do I just change the Upper mounts as my friends have? Or is it more worth it to change the Upper and Lower bushing while I’m already changing it?
Second question is, once I’ve removed the rubber bushing between the Upper and Lower bushing, do I reuse the factory metal ring found at the bottom? I’m well aware I need to remove the old rubber bushing as that’s the whole point doing replacing these bushes.(Refer to diagram below)
If I do reuse the metal ring and place it underneath, then does that mean this person who installed his bushings did it wrong? Is it different because it’s a Corolla? What is the correct order to place the bushings?
Time stamp: 10:56 - 12:01
12:01-12:45 - you see why he uses zip ties for the bushings
Please help me out as my bushings are going bad, very high km and tracked Yaris. Just want to get the most information as possible and don’t want to buy the wrong product.
Thank you all in advanced!
