GR Yaris Sensible operating temperatures?
TheManWithTheStick
Anglesey
Allo there!
Long time no post. Been staying away to avoid spending money I don't have! And sorry if this is the wrong section but I wasn't sure, feel free to move if necessary.
Aaanyway, I use this Torque Pro dashboard when driving my GR:-
I've set some sensors to flash, e.g. when the engine Oil is below 70c (I've seen the OEM warning disappear between 52-55c but the gearbox was still 14c which sounds a bit cold) but these are all best guesses.
I'd like to set proper lower and upper limits on these. I know all oils are different and will likely have different operating temps but maybe there's a 'safe' range that would cover most/all.
Does anyone know what sensible values would be for these?
  • Engine oil (min/max?)
  • Gearbox oil (min/max?)
  • AWD Clutch (overheat only I'd imagine. Anyone know what temperature disconnects the back axle?)
  • Tyres - pressure & temp (min/max?)
  • Intake (no min required)
  • Intercooler (required at all?)
If I'm missing something important or useful here then please let me know. Any info is much appreciated!
Thanks
Marc
Great idea! following this!
In addition to your values, I also have oil pressure and coolant on display.
Oil pressure is the big one at top-right - that's important so is on my primary screen.
Coolant temp changes slowly so I do have it active but on another screen. Plus I can see it on the dash MFD so tend to keep an eye on it there.
Reactions: Max
Nobody? Okay, well this is what I currently have the warnings set at so the dials will flash when outside these limits:-
ComponentMin. limitMax. lmitReason
Engine oil70°C130°CFound reports of hitting 135°C on track so set my warning a little lower
Gearbox oil25°C80°CComplete guess
AWD ClutchN/A80°CAnother guess. Would love to know what temperature this disconnects at, annoying as I'm sure I found this info somewhere in the distant past
Tyres15°C35°CAnd another guess
IntakeN/A35°CGoes very high when stopped. Would love a vented bonnet.
IntercoolerN/A?No idea. Is it even useful when intake is monitored?
Master Cyl.??No idea. I've never seen this go high but maybe it will on track?
The tyre temperature comes from the TPMS so this will differ from the actual tyre surface, but I hope it gives a good idea when they're up to temp. But what is that temperature?
I'd say tyres very much depend on the specific model, gearbox at 25 seems a bit too cold, 35-40 at least to start pushing. Engine around 90 imo.
Yeah I get that about tyres but there must be a 'sensible' range that covers most? I should add that I'm not considering winter tyres, this is just to ensure things are in a good working temp to push-on in reasonable weather.
I'll up the gearbox and engine limits at your suggestion - thank you!
Have you been able to mirrorcast this data to the Toyota screen? I might be tempted to get an Andriod phone...
I have Waze on the main screen while this is on my phone in a Brodit holder. So I haven't even tried but I'll see if I can manage it and let you know.
Edit: Actually, yes it would be much better on the main screen while on track, Waze wouldn't be much use there! Defo looking in to this.
It looks like the OBD2AA software to do this is no longer supported plus I need a rooted phone which I can't be arsed dealing with.
Shame, would be great to have Torque on there for the track. Hopefully some other way comes up in future!
Tyres definitely get warmer than 35°C. This was mine a few days ago after only some mildly-spirited caning with an ambient temp of about 6°C
Yes, the TPMS temps will be different, probably lower, but with an ambient temperature of even 20°C it’s definitely going to be more than 35°C I would’ve thought.
Id say from track experience (not in a GR)....that anything over 120 degrees oil is concerning,even tho ther GR does run quite hot.
Front mount oil cooler a must.
I wait till my oil is over 60 degrees before giving it some.
.cut
Yeah they definitely will, I saw mine reading over 31 recently and it's far from hot outside! I just wonder when they'll start to fall off (I know it'll be different for each tyre), looks like nobody know so I might just have to experiment and report back.
I do have one of those IR thermometers somewhere though, I'll have to dig it out and put in the GR so I can compare the TPMS with the surface temp (y)
Ah okay, I might set that warning a bit closer to 120 then. But yeah I'm defo going to invest in an oil cooler at some point.
Do you check gearbox oil temp before booting it?
Can you share the dashboard and settings for Torque? Might be useful for other users and I could expand my own. Thank you.
It would seem so!
I hadn't thought of that, nice to have a backup. You will probably have to tweak for your phone screen size. And let me know if you have any problem downloading.
Oh, I'm not sure if that is my entire layout or the single screen. If entire then you can swipe one way for default gauges and swipe the other for other ones I've been playing with.
Be aware that you'll need a good OBD adapter for this! I know PIDs like TPMS won't work with some cheap ones (as PhilEvo6 can vouch) but I know for certain it works with OBDlink LX and MX+ adapters.
Tyres, warning above 50C (depends on tyre so look that up if possible, but for road tyres they'll start dropping off in grip going higher, roughly, ps4s probably bit higher)
Intake IAT warning 50C (above you're officially heat soaked)
IC CACT warning 50C (engine drops power above iirc)
For oils, generally above 100C is quite good too, as it evaporates any water moist (usually there is some sort of vent). For the awd clutch I don't know though, would indeed be good to get a warning just before fwd kicks in...
Allo there!
Thanks
Marc
are you running this on the stock headunit?
edit: the answer is in the post, guess i should ask, how did you go about doing this? thanks!
Brilliant stuff!! Exactly the sort of info I needed - thank you sir!
No no, just on the phone but I may have found a way to mirror the phone without root, will update if so.
Basically just Torque Pro on Android with an OBDlink adapter. Dead easy and surprisingly reliable!
I've tried this sort of thing in past cars but always had one problem or another such as really slow gauge updates, but in the GR the gauges update many times per second and it works every time.. just start the car and fire up Torque. And disable lane control. And enable iMT. And set Track mode. And Select Android Auto on the main screen when it randomly decides not to auto-switch.... yeah, "just"... Shit man, firing up the Yaris is starting to feel like f'kin NASA launch!
And then you get in your Evo and it's.... Key... Steering wheel...seat..... Pedals... That's it. 😎😁
