TheManWithTheStick
Allo there!
Long time no post. Been staying away to avoid spending money I don't have! And sorry if this is the wrong section but I wasn't sure, feel free to move if necessary.
Aaanyway, I use this Torque Pro dashboard when driving my GR:-
I've set some sensors to flash, e.g. when the engine Oil is below 70c (I've seen the OEM warning disappear between 52-55c but the gearbox was still 14c which sounds a bit cold) but these are all best guesses.
I'd like to set proper lower and upper limits on these. I know all oils are different and will likely have different operating temps but maybe there's a 'safe' range that would cover most/all.
Does anyone know what sensible values would be for these?
If I'm missing something important or useful here then please let me know. Any info is much appreciated!
Thanks
Marc
- Engine oil (min/max?)
- Gearbox oil (min/max?)
- AWD Clutch (overheat only I'd imagine. Anyone know what temperature disconnects the back axle?)
- Tyres - pressure & temp (min/max?)
- Intake (no min required)
- Intercooler (required at all?)
Thanks
Marc
