- Thread starter
- #281
New Youtube Video about our Carbon Hood.
Larger forge intake pipe would be easy to fit - if you like larger intakes
Yes. But our Turbo Inlet is 76mm and not 48mm as the OEM one. So the Forge wouldn‘t change that much.Larger forge intake pipe would be easy to fit - if you like larger intakes
Or do88Larger forge intake pipe would be easy to fit - if you like larger intakes
Wow that big difference?Yes. But our Turbo Inlet is 76mm and not 48mm as the OEM one.
Nice gains. Yes custom much better with those figures.Yes. But our Turbo Inlet is 76mm and not 48mm as the OEM one. So the Forge wouldn‘t change that much.
The smallest section is now roughly 58mm inside diameter.
We‘re gonna build a bigger intake as big as possible, hopefully 76mm, from the turbo to the Air Filter. But just not now.
Yep. Turbo will be able to produce over 600hp.Wow that big difference?
