GR Yaris Modifying stock muffler to make some noise.
Tento
Hello
I could not stand the uncharacteristically quiet exhaust especially with my loud intake.
I cut open the muffler, big opening from the top and two small from the bottom. Drilled out the spot welds holding in the baffles.
Then I welded in two 1.75" 90 deg elbows I had to slightly modify, keeping the small internal resonators within the muffler intact.
I also welded the skin back together but that shouldn't be necessary if you're lazy.
Car now has personality. It isn't quiet nor loud (except for the cold start). I would say this is how the car should sound from factory.
There is not much drone either.
Video:
This is what greets you when cutting open the muffler. Take notice of the funny little pipes that come after the baffles (large sieves), they seem to be some sort of resonators.
After removing baffles:
New "Y-pipe":
Welded all together and back on car:
Has this been done before?
Muuuuch better. So it drones a bit at higher speeds? :unsure:
Despite conventional wisdom on bolt on mods, a 3" GPF back exhaust was the only thing I noticed a power gain from. Looking at the internals of the OE catback it's clear why!
I tried myself a GPF back exhaust, and wouldn´t say I noticed much apart from noise. It is much more noticiable removing the GPF or changing the DP for a HJS, for instance.
Did those one at a time afterwards and only noticed faster turbo spool. Nothing really came to life untill tuning the ECU.
