GR86 Full Frequency from Rear Speakers?
ninjin
Does anyone know if the rear speaker feed is at full frequency or filtered at the head unit?
The OEM speakers at the rear are so small that they only have midrange and above sound output.
Curious to know if the signal going to them is Full Range.
They are classed as full range coaxials. You can test it by downloading a frequency emulator app on your phone, connecting via bluetooth then setting the balance all the way back so sound is only generated by the rear speakers, drop the test frequency below 100Hz and see what happens.
I use this method to pin point rattles that only trigger at certain frequencies, but can obviously be used to test the speakers.
Have you watched any of the sound system upgrade videos by Cambridge Autosound on YouTube? I seem to remember him saying that those rear speakers are receiving almost nothing from the head unit, which itself max's out quite quickly. I would ideally like to take my GR down to him and have it all sorted (like in his 3rd video on the Neptune Blue), but at around £4k+ it's not a cheap upgrade by any means, especially as I'd have to live in a hotel and travel there and back from Scotland :rolleyes:.
The channel's GR86 content can be found at the hyperlink here.
I've tried that using the PUZU and pink noise and RTA but I still don't think the signal is full range. Whether the HU doesn't give out full range (HPF) or there is some sort of resistor on the rear speaker.
yeah, i've watched his video on the GR they done. Expensive for sure. Volume isn't an issue as I have minimal rear fill but because my PUZU is the older one without dedicated sub out, I have to run the sub out from the rear outputs. If the signal is not full range, the sub wont get any frequencies to play.
Since changing the front set up to 3 way, I've got down the rabbit hole of trying to get some SQ from the set up. Now all that's missing is some low frequencies that only a sub can suffice. Nothing major, just a under seat sub to round out the whole spectrum.
I had to rewire the PUZU Toyota wiring loom to allow full frequency to be fed to the DSP amp for the rear channels, you loose the fade ability from the headunit, but you can set everything from the DSP amp including fade.
What under seat sub did you go for, looked at this but drew a bit of a blank given the dimensions under the seat. Guess that is why the OEM offering (outside of UK 'grey' spec has the sub located in the boot.
That's exactly what I wanted to hear. So it does not feed full frequency to the rear from the head unit!
I haven't bought the sub yet as I wanted to confirm the rear output. When I do get the slim sub, I most probably will just leave it in one of the foot wells of the rear seats or mount it into the boot. I'm not looking for rumbling bass, just an extension of the low end to give me the full spectrum of sound.
The rear channel outputs from the factory head unit have a High Pass Filter at 150Hz.
This thread (link below) shows how to modify a Puzu harness to get a full range signal to the rear speakers, by tapping the front channels. I've not fed a full signal to the standard rear speakers, only upgraded ones, but suspect the standard ones would struggle with that.
I won't be running rear fill once I do the sub. The car is so small I haven't noticed any improvement with the minimal rear fill I have as I prefer front staging.
I've just bought the VIBE Slick10. £130 or so in eBay with discount code.
Will update in a few weeks how it goes, too busy with work at the moment, play stops!
They are filtered at 160hz and almost pass through zero sound. The speakers are a tiny 2.5”. I’ve got an amp and I’ve had to modified the harness to bypass the head units filter. Feed the input into the front channels. That’s the only way to remove the high pass filter. Even with that those speakers produce almost no sound. I’ve replaced mine with 4” speakers in the end.
well... I've gone down the rabbit hole now :LOL:
Bought a PUZU C31s which is a 6ch DSP, with selectable inputs for the outputs. So I will loose the rear fill, run the 6ch to the front components (tweeter, mid, bass) , so full active set up.
I'll be very interested to hear how you get on and where you fit it.
A fully active 6 channel front set up should sound great with the Focal 165AS3. 👍
I've looked into the C31, 6 channel, the reason I didn’t get one is it probably won't sit on top of the glovebox, where the C7 squeezes in.
My thoughts for the 6 channels were; 2 running woofers in the front doors, 2 running 4" midrange and tweeters with crossovers in the dash, and 2 running 4" co-axials in the rear. Independent levels, filters and time delay settings at all 6 locations.
the newer C31s is a serious bit of kit for the money! I'll most probably give it a go at the weekend. If it doesn't fit where the C7 does, I got extension lead and will install the C31s elsewhere. Worst case scenario, under the passenger seat.
