Spirited
- Jan 23, 2022
- 488
- 503
Hey everyone,
I have bought 90105-17013 bolt. I plan to mount them in order to reach - 2.2 ° / -2.3° camber front.
From what I understood, I can have - 2° rear with stock bolts.
That would allow me to have - 2.3° front and -2° rear which seems perfect for me and my "fast road" use. I don't want too agressive camber that would destroy the inner line of my tyres.
However I'm a bit lost when it comes to toe. I am tempted to keep stock toe front/rear as I find the entry balance quite good. Is it a mistake given the camber change ? Should I go for close to neutral front and some toe in rear ? I like a bit of oversteer during entry as I'm used to FWD cars but I don't want the yaris to try to kill me during fast corner entry either.
What would be the recommandation ? Stock suspensions, standard PS4S. Thanks !
No expert here; so, just sharing some thoughts rather than recommendations.
I am under the impression that rear camber is not adjustable with stock bolts. You may already have - 2 deg camber there by coincidence, in which case, great for you. But you may as well have a different setting and also significantly different settings on each side. There are aftermarket bolts that you can use to bring the rear camber at - 2 deg.
I can't see a problem with - 2.3° front and -2° rear, especially if you're coming from FWD cars.
Regarding toe:
- front is more of a personal preference rather than safety matter, as understand it. I can't see anything wrong with sticking to stock values or specifically middle of that range, even with your altered camber. However, I recall that stock values are a wide range. (Also, I have opted for toe out, as I like the eagerness this offers and take every opportunity to minimise understeer.) For @Onehp 's usefully simplifying view of the effects of getting from slight toe-in towards neutral, see https://www.gr-yaris.co.uk/posts/43405/
- rear is a matter of preference, but also a safety consideration. If, as you mention, you don't want the car to try to kill you, you just stick to well within stock values, install a harder rear trailing arm bush and still be mindful crests, lift-off oversteer, etc.
