Michael Knight
Using weldspeed manifold improved the mid range response so I hardly have any lag - of course turbo has its best operting window btw 4-6k but pulls well also from lower rpm.
So an intercooler with similar volume but greater frontal area would be ideal?It's already been discussed here. It's simple physics. There is the case where the IC is overheated and then a better IC will help reduce lag, but all else the same, more volume will take longer time to increase pressure. It's only a matter of tenths of a second, depending on driving that doesn't matter at all, or it does...
Try C-Tec its the best intercooler by far!So an intercooler with similar volume but greater frontal area would be ideal?
For lag on a car running hot, yes. If temps are ok, stay stock.So an intercooler with similar volume but greater frontal area would be ideal?
Looks nice but I'd imagine fairly expensive to ship to Australia.Try C-Tec its the best intercooler by far!
Based on what? The squared of end tanks don't look at all impressive from a flow perspective at least, dumping a high speed flow in an open volume without transitions is one of the worst sins in flow optimisation... close second is cramming in slow flowing flow from the tank into a pipe without transitions on the other end. Nor is the height special. Let's hope the core is top quality then... (can't judge that...)Try C-Tec its the best intercooler by far!
What are your thoughts on the PWR? https://pwrshop.au/products/toyota-...ight-racer-intercooler?variant=47396972789993Based on what? The squared of end tanks don't look at all impressive from a flow perspective at least, dumping a high speed flow in an open volume without transitions is one of the worst sins in flow optimisation... close second is cramming in slow flowing flow from the tank into a pipe without transitions on the other end. Nor is the height special. Let's hope the core is top quality then... (can't judge that...)
Look similar to most other offerings. Tanks look ok, core is light tube and fin as are most the other more exepensive offerings. Unfortunately very hard to judge actual IC performance as there are no specs (except a few mentioned before) or comparison tests, and dyno's from different corners of the world are very blunt comparison tools. If you know the manufacturer and they are local, that counts for something too, in the end the biggest upgrade is upgrading, differences between upgraded IC are not so easy to compare, but we can at least try to pick one that is as close as possible to the goals of the build...What are your thoughts on the PWR? https://pwrshop.au/products/toyota-...ight-racer-intercooler?variant=47396972789993
Hi the core is Garret, and from the "butt" dyno seems to have a positive effect. Acknowledge its not a very informed review, but the unit seems a quality piece of kit and look OEM (Which i like). I'm planning on dyno sessions soon, so may be be able to offer some data!Based on what? The squared of end tanks don't look at all impressive from a flow perspective at least, dumping a high speed flow in an open volume without transitions is one of the worst sins in flow optimisation... close second is cramming in slow flowing flow from the tank into a pipe without transitions on the other end. Nor is the height special. Let's hope the core is top quality then... (can't judge that...)
That is good to hear, my concern with the big coolers like the Airtec and process west is the weight right over the nose.From my experience: I installed the Stage 3 Airtec intercooler, with the upgraded bigger pipes all around.
I was expecting to have some increased lag, but for my surprise, the lag is the same, or even reduced!
The car mods at the time were only:
- Closed Air intake (Airtec)
- Stiffer lowe engine/gear mount (Cusco)
- Stock ECU and no tuning
not that big issue, provides better weight transfer on brakesThat is good to hear, my concern with the big coolers like the Airtec and process west is the weight right over the nose.
Been considering the Airtec intercooler, since the volume increase is modest compared to many of the others, and the price is on the lower end.
However, it seems like it is quite heavy? Anyone know how much heavier it is than stock, and how much it actually weighs?
Are we talking several kilos over the Wagner for example?
Any other intercoolers out there that don't massively increase volume, which add less weight, and don't cost a fortune?
I know the do88 comes highly recommended, but it's expensive, and it requires cutting various plastic air guides.
