Yeahhh hold up, my car lurches forward when you're slowing in traffic with iMT ON so it's only useful/good when you're really pushing on. No use being ON all the time... 😐
Seems like you might have an issue with your iMT configuration if you're the only one having this happening. 🤷‍♂️
Mine has been on the rollers yesterday. Awaiting results as I’m too laid back to ask 🤣
I replaced the exhaust with defap+silent+silenced final… from a tuner here in Italy… I really like the sound but then looking at the exhaust etc, I discovered that the connection between the central and defap is with a collar (like v1 akrapovic), and I discovered that in this car the exhaust does not have a flexible part (like many cars) which avoids stressing the connection to the turbo with the movement of the exhaust… does this not create problems?
The coupler between the cat and the GPF pipe has sprung bolts to allow a bit of movement, seems to work ok.
See you’ve taken your winter wheels off…. I took mine off today! Slightly late as it seems to have warmed up significantly and doesn’t appear it’s going to be cold again any time soon.
What’s the goal here? Have you done any mods? Have Whifbitz tuned it for you?
It was in for brake line fitting and exhaust development. Mods wise, it has an Eventuri intake, enlarged piping to turbo, Airtec inlet manifold, oil cooler, intercooler, torque mount header tank and so on.
My goal is 350-400bhp then suspension. Tuning wise EcuTek are currently working with Litchfield on the Gen 2 so something should be coming our way.
Yes, it is easy(but you might not like it) connect your phone and save it to a car driver/user profile, and it will stop showing this . As it will load the profile automatically upon detecting your phone.
You mean with the myT app? It is disabled here in Norway. Have to use MyToyota app and couldn’t get that to work.
MyT is old and depreciated, MyToyota is the new one that is updated, what is not working for you ?
And anyway, i am not talking about the app, either it is an Apple or Android phone, connect it through your car with bluetooth, enable carplay Android Auto if you wish, save that phone under your user profile in the car, and that splash screen with the choice will dissapear.
Here you go !
Here you go !
Thank you🙏🏻 I do use carplay, but I haven’t saved any user profile. Will try it!
