assuming the rings installed will not be adjusted by gap during install (?) but are in spec from the factory so it would return the same issue in all engines (if such issue exist, in first place). if it would, one might think Toyota would react.Interestingly, someone else already checked Toyota's Microcat for the original piston part numbers for the GR Yaris (Gen 1 and Gen 2) and the GR Corolla. Here’s what they found:
- GR Yaris Gen 1: 13101-18030
- GR Yaris Gen 2: 13101-18040
- GR Corolla (up until September 2024): 13101-18040
- GR Corolla (from September 2024 onwards): 13101-18050
Notably, the latest GR Corolla has different pistons compared to the GR Yaris Gen 2. This raises the question: Did Toyota actually fix the problem in the GR Yaris Gen 2?
Despite these different piston part numbers, all of them use the same piston rings: 13011-18040.
I've worked in warranty. A high stressed engine, real worlds conditions, many parts involved there is always a certain failure rate. Only Toyota will sit on the correct data. Ten engines mentioned in the second vid is quite anecdotal without context, and I kinda doubt many of them were 100% stock. Car manufacturers will dyno and test the hell out of their engines before releasing them, but a badly judged tune or box is all that is needed to throw all that works out of the window....
This is already being discussed here also
GR Yaris - Balance of tuning and durability limits
I’m still yet to see a destroyed GR Yaris engine running on stock form. He says there are, with no more data but it is difficult to trust his claims. There may be a few, nothing odd when there are ~30'000 of them around and that's what warranty is for. Also the reason I created this thread, it...www.gr-zoo.com
I find it hard to believe that all GRY/GRC engines have this issue and could fail catastrophically at any moment, even in stock form, while using the highest grade oil and fuel.
Thoughts?
In my opinion GR has been designed to meet a certain performance. its good for its purpose, but if you plan to get 350hp from it with a chip tune then good luck with the engine longeivity. Suspecting all or most of the failed engines have had quite serious abuse and/or tuned engine. The oil system in the car is not perfect especially if tracking, but dare to say it will not explode if you drive normally and service it normally. So yes, the topic is bit a tempest in a tea cup.This youtube channel leaves me always full of doubts...
It's usually much competent and thorough, but sometimes it looks like it exaggerates things too much.
Once the Mk2 was launched, their first video was like "About time, the Mk1 has so many problems that a new model was long overdue", and this was after many of their videos celebrating the qualities of Mk1.
Then this video.
For sure it's useful to know about it, but the problem they highlight is described really as a random one, that could happen on any Mk1 car, if bad circumstances align in the wrong way in a sudden deceleration.
And in the end, he contradicts himself by telling us not to worry, because it is a problem limited to few cars...
Not true, because if the cause is related to a design flaw in all pistons, then it could really happen on any car with stock pistons.
I guess this should not be classified as a severe design flaw, but as a random problem that could occur to any engine with high performances, otherwise all 40k Mk1s in the world should get a broken engine sooner or later.
Exactly, I totally agree with you, and what's really a too long shot in this video is stating that it can happen to any engine, any car, at any time, even to 100% stock cars that never saw a track.In my opinion GR has been designed to meet a certain performance. its good for its purpose, but if you plan to get 350hp from it with a chip tune then good luck with the engine longeivity. Suspecting all or most of the failed engines have had quite serious abuse and/or tuned engine. The oil system in the car is not perfect especially if tracking, but dare to say it will not explode if you drive normally and service it normally. So yes, the topic is bit a tempest in a tea cup.
Sure, I remember that Ford mounted a wrong gasket (from the Mustang, if I remember well) on some engines of the Focus RS Mk3, causing bad lubrication, and engine failures in the worst cases.I suspect these 10 engines have been modified and driven in a way that the vast majority of us won't replicate.
It got me trying to remember other makes of car that have had serious engine problems.
The first I came up with was the ford engine - I believe on their RS ralley version and other eco engines.
Recently seen a report about Stelantis engines causing problems again with wet belts.
I am sure other people can remember other engines so a few toyota engines going bang is par for the course. It seemes to be lifting off at high speed sudenly.
I doubt it is a problem for the vast majority for us but does remind me how important my yearly service down at my local MrT centre is - and driving it respectfully to my little 3 pot.
Yup i agree! That video is on 14K views and over 300 comments now. Surely some of the "30 in Italy only "engines that have allegedly gone bang are in or read this forum. Lets start making a list of blown engines because this guy AJ or Toyota are not going to confirm either way. I only deal in facts and data like most of us.Yeah, the first thing that comes to mind are the infamous rod bearing failures in the S54 and S65 engines. The irony is that 99% of owners who religiously warmed up their cars and performed regular oil changes never faced these failures, despite how common they were made to seem, with the internet blowing things way out of proportion.
What I’d really like to know is how many bone stock GR Yaris models have actually experienced this failure, with a verifiable source to back it up. So far, all I’ve heard is hearsay and ‘trust me, bruh’ kind of evidence.
Or it could be bad tune?Second one was the piston 2 explosion and current analysis is that it was because of poor fuel, (race) car was running motec and the analysed octance rating was 97.2 that is too low maybe for the map used.
define bad tune. if the map has been designed for race fuel and for oct98, it doesn't work with lower octane.Or it could be bad tune?
I’m not sure I can give you a dictionary-worthy definition of a 'bad tune' but it could involve things like poor fuel and ignition mapping, incorrect transient handling, temperature mismanagement, and so on. I'm not an expert, though. Bad – the kind that blows an engine, I guess.define bad tune. if the map has been designed for race fuel and for oct98, it doesn't work with lower octane.
if you use the car with the fuel that it is not intended to, its not a bad tune, its a poor maintenance and use of the vehicle.I’m not sure I can give you a dictionary-worthy definition of a 'bad tune' but it could involve things like poor fuel and ignition mapping, incorrect transient handling, temperature mismanagement, and so on. I'm not an expert, though. Bad – the kind that blows an engine, I guess.
In any case, hard to blame the engine if it was running different ECU and custom mapping.
