GR Yaris Air intake
Do you have the older style larger filter that they initially supplied, or the newer smaller filter? Because they changed the filter size to help with idling as far as I know.
I got the newer one with the smaller filter. The idle seemed fine after the cold start procedure ended.
Don' think so, but you can download the file on the link below and have it printed in some local 3D printshop, think it was around 200-250€ in my case for 2 sets.
Can someone help me out with getting the "STL" file?
Unfortunately Thingiverse list the file no more
Thanks for reuploading, I want to keep the OEM filtering so this is ideal.
My knowledge of 3D printing is lacking but I've found a site where I can get a quote to have the parts printed and shipped but I need to know what infill % I should select? Thanks in advance.
I have also uploaded Print Profiles that i have used. Even if you have not the sane Printer you can look at the Values i used to print the Parts.
Nevertheless- you make no Mistake if you use 15-20% because the Parts are thin.
As I’ve recently bought a piece of onehp’s (ex)GR, I have remaining a complete unused set of Helmut’s great Scoop System for sale. If interested let me know via pm.
cheers
CrUzO
so I decided to go for it and ordered Helmut's scoop kit, it's going to be printed using ASA material which has higher temp resistance than PETG and ABS, will also be installing the forge turbo inlet piping down the line also
main thing I wanted is constant cold air flow but OEM filtering, especially when the majority of the aftermarket intakes claimed improvements are done on a dyno with no airflow and I suspect are probably are at the expense of filtration quality.
cheers
CrUzO
PM sent
Hello CrUzO.
Part arrived today great service thanks.
Quality printed item as well 👌
Shout out to Helmut who's produced the design for us to use 👍
Regards Russ......🙏
cheers
CrUzO
Hello mate, you still have some extra there?
I’m sorry mine’s sold already. Maybe there’s a 3d printer service in your country as Helmut has gifted his 3d printer design files for the community for free!
I used Craftcloud to get helmuts air intake scoop kit printed recently, you just upload the STL files and it'll give you quotes for printing in all sorts of materials, from various 3d printing companies, was approximately £150 for all 3 parts printed in ASA about 2 weeks ago.
What material did you use for printing or what do you recommend?
Thanks
Finally got around to fitting, used split pins for the metal clips, gave the scoop a light coat of simoniz satin black tough paint I had lying around as a small amount of the layers were more grey than black, didn't bother with the box or stand. Couldn't get the cable clip in at the side in so will need to file it out or buy clip that fits.
Made the holes 8mm at the top and bottom of the stand and inserted M8 to M6 thread reducers rather than screwing a bolt into the printed plastic, then used a black M6 button head bolt at the top and an 10mm M6 bolt and washer at the bottom
Just fitted the MST v2. Other than the stupidly difficult to remove lower M8 bolt for the original inlet pipe it wasn't a bad job really.
MST kit and instructions are all spot on, not driven enough to say if it's any different yet but the placebo effect is making it feel like throttle response is improved a little bit :)
